mathdad
- 1,283
- 1
RTCNTC said:See picture for question.
Joppy said:You recently posted a question quite similar to this one and received a thorough answer. Could you highlight what you are having trouble with here?
The equation is asking for the values of x that make the inequality x|x+2|<5 true when x is subtracted by 2.
To solve this equation, you can follow these steps:1. Simplify the absolute value expression by considering both positive and negative cases.2. Solve for x in the resulting inequality.3. Add 2 to the solutions to get the final values for x.
No, you cannot use any value for x. The values of x must make the inequality x|x+2|<5 true, otherwise they will not be considered as solutions.
Yes, there can be more than one solution for this equation since it is an inequality. The number of solutions will depend on the value of x and the inequality.
You can check your solution by substituting it back into the original inequality. If it satisfies the inequality, then it is a valid solution. You can also graph the equation and see if the solution falls within the shaded region.
