Can You Use a Stone to Retrieve Your Frisbee?
  • Thread starter veg
In summary, the stone dropped from the well had a final velocity of 10m/s, which is 4 meters less than the final velocity of 16m/s. So, the stone would hit the frisbee.
veg
Your roommate accidentally tosses your Frisbee onto the roof of a 16m high building. You figure you are going to have to go looking for a ladder, but as you stare up at your favorite competition disk, you realize you could possibly knock it loose with a stone. You don’t want to look like an idiot in front of your roommate however, and the well in the courtyard suddenly gives you an idea. You drop a stone into the well and note that you hear a splash 2.0s later. You repeat the experiment with another stone, but this time you throw the stone down as fast as you can. This time the splash comes 1.0s after the stone leaves your hand. Armed with this information you carry out a quick calculation. Can you use the stone, or do you need to go get a ladder?
so far i used this equation to find Vf or final velocity which I am sure is height of Δx
Vf = Vi + aΔt
Vf = 0m/s + 10m/s (2s) = 20
so from what i can kind of get from this problem is that there is 3 different scenarios i need to solve for. i get the first scenario or easy one. I am just not sure what to do about the other two or if i am on the right track?
Welcome to PF.
You need to show us your work and we can give you hints on how to solve the problem. We can't do the work for you.
So basically you need to decide: use a ladder ot throw a stone
What does dropping a stone in the well tell you about the well?
Throwing a stone down the well what does that tell you about your throwing capablity?
From what you now know which is it use a ladder or throw a stone?
I gave away too much.
Well i drew three pictures. the first picture is a well with initial velocity of 0m/s. an acceleration of 10m/s (problem said use 10 not 9.8) a time of 2 seconds. which is basically a simple free fall question so...
Vf = Vi + a * t
Vf = 0m/s + 10m/s * 2 seconds
dropping the stone gives final velocity which would also be height of well because it falls at constant speed so the well is 20 meters deep (delta x).
since the well is 20 meters deep i would assume we could hit the frisbee since it is only
16m which is 4 meters less than the 20 meter well.
but I am not sure how to apply this to solve what i see as two other problems
which would be the initial velocity of the stone in the second well and not even sure what to do about the 16 m high building.
Knowing the depth of the well and the time it took a rock to hit the bottom, you can compute the initial velocity with which the rock was thrown down the well. BTW it's not 20m, it's somewhat less than that.
You cannot compare 16m with the well depth directly.
so based on what you said i would take this equation Vf = Vi +at and rearrange it to get this Vi = Vf - at so plugging in numbers i would get Vi = 20m/s - 10m/s * 1s = 10
also not sure what you mean by "it's not 20m, its somewhat less than that" do you mean I am off. Only thing i could think of was using 9.8m/s for a instead of 10m/s but problem said to use 10m/s
You appear to be confused between acceleration, speed and distance.
The stone falls, whether thrown or dropped, at constant acceleration. You computed the final speed when dropped. You have not computed the depth of the well.
Δx = Vi* t + .5at^2
Δx = 0m/s * 2 + .5(10)2^2
Δx = 0 + 20
so it would just be 20 meters deep right?
No, your equation should be s = vi*t + at^2/2 where s is the depth you just calculated.
If you're using g = 10m/sec^2 then s = 20m is right. I think your instructor was dumb to have you use g = 10 m/sec^2.
yeah, when i read that i wasn't sure why 10 was being used. ill have to ask because its usually 9.8. but now that i know depth of well (20m) for the first part of problem then the initial velocity would be 10m/s for the second part of problem (throwing rock in well right??). This is where i am now stuck. I am not sure how to apply this to getting a ladder or throwing a rock. so here is what i know and am confused about
a = 10
x = 20
Vi = not sure one is 0m/s for free fall and the other is 10m/s for throwing it in well
Vf = 20m/s
t = not sure two are given 1 and 2 seconds for two problems
Never mind vf. Use s = vi*t + at^2/2 to get vi.
You needed the 2 sec to determine the well depth. Now you need the 1 sec to determine vi.
Related to Can You Use a Stone to Retrieve Your Frisbee?
1. Can a stone be used to retrieve a Frisbee?
Yes, a stone can be used to retrieve a Frisbee. However, this method may not be as effective or efficient as using other tools specifically designed for retrieving objects.
2. Is it safe to use a stone to retrieve a Frisbee?
Using a stone to retrieve a Frisbee can be safe if done carefully and with caution. It is important to choose a stone that is not too heavy or sharp to avoid causing harm to oneself or others.
3. What are the advantages of using a stone to retrieve a Frisbee?
Using a stone to retrieve a Frisbee can be advantageous if no other tools are available. It is also a simple and cost-effective method. Additionally, using a stone can be a fun and challenging activity for some individuals.
4. Are there any disadvantages to using a stone to retrieve a Frisbee?
Yes, there are some disadvantages to using a stone to retrieve a Frisbee. It may not be as accurate or reliable as using other tools, and it may require more effort and skill to successfully retrieve the Frisbee. Moreover, using a stone may increase the risk of injury if not done carefully.
5. Are there any alternative methods to retrieving a Frisbee besides using a stone?
Yes, there are several other methods that can be used to retrieve a Frisbee. Some examples include using a Frisbee retriever, a long stick, or simply running to retrieve the Frisbee. These methods may be more effective and safer than using a stone.
