Can You Verify the Integral of Secant Squared Over (1+Tangent)^3?
In summary, the conversation is discussing the integral of $\frac{\sec^2(t)}{(1+\tan(t))^3}$ and using the substitution $u=1+\tan(t)$ to simplify the integral. The final answer given by the TI is off by a minus sign, but the derivative can confirm that it is the correct answer.
karush
MHB
3,269
$$\int\frac{\sec^2 \left({t}\right)}{\left(1+\tan\left({t}\right)\right)^3}dt$$
$$u=1+\tan\left({t}\right)\ du=\sec^2\left({t}\right) dt$$
So far ok?
So far ok?
Yep. (Nod)
$$\int\frac{1}{{u}^{3}}du =-\frac{1}{{2u}^{2}}=\frac{1}{2 (1+\tan\left({t}\right)) ^2 }+C$$
I hope the TI gave a different answer?
You've lost a minus sign in the final answer, but otherwise we can verify that if we take the derivative we get indeed the original integral.
FAQ: Can You Verify the Integral of Secant Squared Over (1+Tangent)^3?
What is the general formula for integrating $$\frac{1}{u^3}du$$?
The general formula for integrating $$\frac{1}{u^3}du$$ is $$\int \frac{1}{u^3}du = -\frac{1}{2u^2} + C$$, where C is the constant of integration.
What is the process for integrating $$\frac{1}{u^3}du$$?
The process for integrating $$\frac{1}{u^3}du$$ involves using the power rule, where the power of u is increased by 1 and the new exponent is divided by the new coefficient. In this case, the integral becomes $$\int \frac{1}{u^3}du = \frac{1}{-2}u^{-2} + C = -\frac{1}{2u^2} + C$$
Can the integral of $$\frac{1}{u^3}du$$ be simplified further?
Yes, the integral can be simplified to $$-\frac{1}{2u^2} + C$$ by using basic algebraic manipulation.
What is the domain of integration for $$\frac{1}{u^3}du$$?
The domain of integration for $$\frac{1}{u^3}du$$ is all real numbers except 0, as u cannot be equal to 0 in the denominator.
Are there any special cases to consider when integrating $$\frac{1}{u^3}du$$?
Yes, if the integral is in the form of $$\int \frac{1}{u^3}du$$, then it can be evaluated using the formula mentioned in the first question. However, if the expression is in a different form, such as $$\int \frac{du}{u^3}$$, then it can be solved by using substitution or u-substitution.
