neurohype
- 6
EDIT: If you're reading this and are still learning algebra basics, IGNORE this. I made a wrong assumption, thanks to MarkFL for pointing that out!
So far, I was led by my own assumptions to believe that this:
a1
\(\displaystyle \frac{1}{5} + \frac{y}{2} = 7\)
could be turned into this:
a2
\(\displaystyle \frac{2}{10} + \frac{5y}{10} = \frac{70}{10}\)
to then cancel the denominators all across and get this:
a3
\(\displaystyle 2 + 5y = 70\)This seemed to work fine and did wonders until some of my answers did not match the textbook's answer section where equations had more than one variable on the same side. I just want to know: is this a rule of some sort or are my now corrected assumptions (can cancel out as long as different variables are on opposite side) invalid still? (I'll re-ask at the end of this post in case this post gets across as messy).
I'll demonstrate what I now believe to be wrong then what I believe to be right :
-- Believed Wrong: -------
b1
\(\displaystyle \frac{x}{5} + \frac{y}{2} = 7\)
is transformed into:
b2
\(\displaystyle \frac{2x}{10} + \frac{5y}{10} = \frac{70}{10}\)
cancels out to:
b3
\(\displaystyle 2x + 5y = 70\)
-- Believed Right: ---------
c1
1st, make sure different different variables are transferred on different sides BEFORE canceling out method :
c2
\(\displaystyle \frac{y}{2} = \frac{-x}{5} + 7\)
c3
\(\displaystyle \frac{5y}{10} = \frac{-2x}{10} + \frac{70}{10}\)
c4
\(\displaystyle 5y = -2x + 70\)
(which you'd then do y = other side over 5, etc, I'm only illustrating the canceling out part)So just to recap, is it right to believe that canceling out using the "same denominator" method requires that no two or more different variables be on the same side of the equation?
a1
a2
a3
b1
b2
cancels out to:
b3
c1
c2
c3
c4
