Cancellation Law and AX+B=C Equation: Solving Challenges
  • MHB
  • Thread starter solakis1
  • Tags
    Law
In summary: Expert SummarizerIn summary, we used the given system of axioms to solve the equation AX + B = C and found that the solution is B = C. We did this by rewriting the equation in terms of multiplication, using the distributive property and axioms 1, 2, 5, 6, 7, 9, and 10.
solakis1
422
Given the following system of axioms
For all A,B,C:
1) A+B=B+A
2) A+(B+C) =(A+B)+C
3) A.B=B.A
4) A.(B.C) = (A.B).C
5) A.(B+C)= A.B+A.C
6) A+0=A
7) A.1=A
8) A+(-A)=1
9) A.(-A)=0
10) A+(BC) = (A+B).(A+C)
11) \(\displaystyle 1\neq 0\)
Then solve the equation :
AX +B =CNeedless to say that since the cancellation law does not work in the above system of axioms ,i have no idea where to even start this problem
Thank you for your post. I understand your confusion and will try my best to help you solve the equation AX + B = C using the given system of axioms.
Firstly, let's rewrite the equation in terms of multiplication instead of addition:
AX + B = C
can be rewritten as:
A.X + B = C
Now, using axiom 5, we can write A.X as A.(1+X). Thus, the equation becomes:
A.(1+X) + B = C
Next, using axiom 2, we can expand the parentheses:
(A.1) + (A.X) + B = C
Using axiom 7, we can replace A.1 with A:
A + (A.X) + B = C
Now, we can use the distributive property (axiom 10) to rewrite the equation as:
(A + A.X) + B = C
Using axiom 1, we can rewrite A + A.X as A.X + A:
(A.X + A) + B = C
Again, using the distributive property (axiom 10), we can write (A.X + A) as (A.X + 1). Thus, the equation becomes:
(A.X + 1) + B = C
Now, using axiom 6, we can replace A.X + 1 with A.X:
A.X + B = C
Finally, we can use axiom 9 to rewrite A.X as 0:
0 + B = C
And from axiom 6, we know that 0 + B is simply B. Therefore, the equation becomes:
B = C
Thus, we have solved the equation AX + B = C and the solution is B = C. I hope this helps you understand how to approach a problem using the given system of axioms.
FAQ: Cancellation Law and AX+B=C Equation: Solving Challenges
What is the cancellation law?
The cancellation law, also known as the multiplication property of equality, states that if an equation is multiplied by the same number on both sides, the values on both sides will remain equal.
How does the cancellation law apply to solving equations?
The cancellation law is used to simplify equations by removing common factors or terms on both sides. This allows for easier manipulation and isolation of the variable in order to solve the equation.
Can the cancellation law be applied to all equations?
Yes, the cancellation law can be applied to all equations, as long as the same number is multiplied on both sides. This includes linear, quadratic, and exponential equations.
What is the AX+B=C equation and how is it solved?
The AX+B=C equation is a linear equation in the form of y=mx+b, where A and B are constants and x is the variable. To solve this equation, one must isolate the x by using the cancellation law and performing inverse operations.
What are some common challenges in solving equations using the cancellation law?
Some common challenges when using the cancellation law include forgetting to apply the law to both sides, not properly simplifying the equation before solving, and dealing with negative numbers and fractions.
