Cancellation of terms, Kittel (first edition) equation 6.4
  • Thread starter Thread starter Irishdoug
    Terms
The discussion revolves around understanding the cancellation of terms in Kittel's equation related to the average energy in a system of particles. Participants clarify the mathematical steps leading to the cancellation, emphasizing that the integration over certain variables can be separated and simplified. The key point is that the integration over the momentum variables allows for the removal of terms that do not depend on specific variables, leading to a clearer expression for the average energy. There is also a correction regarding the treatment of the integration limits and the significance of the constants involved. Overall, the conversation aims to clarify the mathematical reasoning behind the cancellation of terms in the context of thermal equilibrium.
Irishdoug
I am self studying and cannot understand a cancellation of terms that occurs in the text.
In thermal equilibrium at temperature T, with N particles all of mass N, the internal energy is equal to the kinetic energy i.e. U = E
$$E = \frac{1}{2M} \sum_{i=1}^{N} (p_{xi}^{2} + p_{yi}^{2} + p_{zi}^{2})$$
$$E_{average} = U = \frac{\frac{1}{2M} \sum_{\alpha = 1}^{3N} p_{\alpha}^{2} \int_{-\infty}^{\infty} \Pi_{\beta = 1}^{3N} e^{\frac{-p_{\beta}^{2}}{2M k_{b}T} }dp}{\int_{-\infty}^{\infty} \Pi_{\beta = 1}^{3N} e^{\frac{-p_{\beta}^{2}}{2M k_{b}T} }dp}$$
as we know from classical physics that the average value of a quantity A in thermal equilibrium is
$$A_{average} = \frac{A(p,q) \int_{-\infty}^{\infty} e^{\frac{-E}{k_{b}T} }dpdq} {\int_{-\infty}^{\infty} e^{\frac{-E}{k_{b}T} }dpdq}$$
I'm happy I understand why the dq terms cancel out. So,
This term reduces to
$$E_{average} = U = \frac{\frac{1}{2M} \int_{-\infty}^{\infty} p_{\alpha}^{2} e^{\frac{-p_{\alpha}^{2}}{2M k_{b}T}} dp_{\alpha}} {\int_{-\infty}^{\infty} e^{\frac{-p_{\alpha}^{2}}{2M k_{b}T}} dp_{\alpha}}$$
I do not see how this occurs. I have attempted to play around with the exponentials e.g. using ##e^{a-b} = \frac{e^{a}}{e^{b}}## but here I am left with ##e^{0}##. I have also explicitedly written out the summation and multiplication but it does not seem to help.
Any help or tips appreciated.
Irishdoug said:
Homework Statement:: I am self studying and cannot understand a cancellation of terms that occurs in the text.
Relevant Equations:: In thermal equilibrium at temperature T, with N particles all of mass N, the internal energy is equal to the kinetic energy i.e. U = E
No help so far, so I'll give it a first shot (don't have the full answer - can't find your source; 1st ed ? Thermal physics, or solid state physics?)
You really want to be as accurate as possible when doing things like this, so check what you wrote. You mean
temperature ##T##, with ##N## particles all of mass ##\bf M##.
$$E = \frac{1}{2M} \sum_{i=1}^{N} (p_{xi}^{2} + p_{yi}^{2} + p_{zi}^{2}) \tag 1 $$
So this is the total energy for ##N## particles in three dimensions. Is that what you meant ? Otherwise a 'small' correction is needed (##\frac 1 N##) .
No, that can't be the case, because
$$A_{average} =
is incorrect. Do you mean$$
A_{average} =
\frac{\int_{-\infty}^{\infty} A(p,q) \ e^{-\frac{E}{kT} }dp\,dq}
{\int_{-\infty}^{\infty} e^{-\frac{E}{kT} }dp\,dq}\quad ?$$
Good. We note that ##dp\,dq## is shorthand for ##\ d^{3N}p\, d^{3N}q\ ## and the ##(p, q)## in ##A(p, q)## is shorthand for ##(p_1, \ldots, p_{3N},\,q_1, \ldots ,q_{3N})\ ## and, if ##A(p,q) = A(p)## , the integrations over ##dq_i## can be taken out and integrated (namely to what value ?), and then the factors in numerator and denominator cancel.
So, you want to look at $$
E_{average} =
\frac{{\displaystyle \int_{-\infty}^{\infty}} E \ e^{-\frac{E}{kT} }dp\,dq}
{{\displaystyle \int_{-\infty}^{\infty}} e^{-\frac{E}{kT} }dp\,dq}$$
with ##E## as in ##(1)##, independent of ##q##. We've seen we can drop the ##q##.
With an eye on the next equation it looks as if the expectation value of the sum is the sum of the expectation values. Is that a reasonable phrasing of your problem ? i.e. swapping the ##\sum## and the ##\int## ?
Hi BvU. Thankyou for the response. I'm using Kittel's solid state book. Sorry I thought he only had that one. And yes I have the first edition (and the 7th!). I feel from a cursory glance he goes through the maths in a more understandable way in the first, at least in some sections. I am busy today so will get back to going through your response in more detail later, where I may or may not have more questions.
'No, that can't be the case, because'
Yes that was an error I meant to write what you wrote!
Thanks again.
A_{average} =
{\int_{-\infty}^{\infty} e^{-\frac{E}{kT} }dp\,dq}\quad ?$$Good. We note that ##dp\,dq## is shorthand for ##\ d^{3N}p\, d^{3N}q\ ## and the ##(p, q)## in ##A(p, q)## is shorthand for ##(p_1, \ldots, p_{3N},\,q_1, \ldots ,q_{3N})\ ## and, if ##A(p,q) = A(p)## , the integrations over ##dq_i## can be taken out and integrated (namely to what value ?), and then the factors in numerator and denominator cancel.
E_{average} =
$$A_{average} =
Yes I meant this indeed.
So I'm viewing it as follows:
p = $$(p_{x1}, p_{y1}, p_{z1} ; p_{x2}, p_{y2}, p_{z2}... p_{xN}, p_{yN}, p_{zN})$$
so
dp = $$(dp_{x1}, dp_{y1}, dp_{z1} ; dp_{x2}, dp_{y2}, dp_{z2}... dp_{xN}, dp_{yN}, dp_dp_{zN})$$
Let's assume N = 1 and for ##alpha = 1## we have
$$ U = \frac{\frac{1}{2M} \int_{-\infty}^{+\infty} (p_{x1}^2 + p_{y1}^2 + p_{z1}^2) (e^{c p_{x1}^2}.e^{c p_{y1}^2}.e^{c p_{z1}^2}.e^{c p_{x2}^2}.e^{c p_{y2}^2}.e^{c p_{z2}^2}.e^{c p_{x3}^2}.e^{c p_{y3}^2}.e^{c p_{z3}^2}) dp_{x1}dp_{y1}dp_{z1}} {\int_{-\infty}^{+\infty} (e^{c p_{x1}^2}.e^{c p_{y1}^2}.e^{c p_{z1}^2}.e^{c p_{x2}^2}.e^{c p_{y2}^2}.e^{c p_{z2}^2}.e^{c p_{x3}^2}.e^{c p_{y3}^2}.e^{c p_{z3}^2} dp_{x1}dp_{y1}dp_{z1} }$$
where $$c = \frac{1}{2Mk_{B}T}$$. We can now split this into 3 different integrals e.g
I can't get this to format, but all the constant terms i.e those not dependent on ##dp_{x1}## come outside in the first integral, those that don't depend on ##dp_{x2}## come outside etc.The terms can be seen to cancel leaving
$$\frac{\int_{-\infty}^{\infty} p_{x1}^2 e^{c p_{x1}^2} dp_{x1}}{\int_{-\infty}^{\infty}e^{c p_{x1}^2} dp_{x1}} etc.$$
Does this sound reasonable?
I'm thinking 0 but maybe this would cause the whole eqaution to be 0. I will have to think about it more!
I think that's the idea, yes.
Irishdoug said:
I'm thinking 0
Nope. ##\int_{q_{min}}^{q_{max}} {\rm dq}\ ## is simply ##{q_{max}}-{q_{min}} ## so the lot of them multiplied with each other give you a volume. Which cancels against idem in the denominator.Disclaimer: I'm a little out of my depth here - based on memories from student-times long ago. Perhaps @vanhees71 can shed some more didactically responsible light on this ... ?
BvU said:
I think that's the idea, yes.Nope. ##\int_{q_{min}}^{q_{max}} {\rm dq}\ ## is simply ##{q_{max}}-{q_{min}} ## so the lot of them multiplied with each other give you a volume. Which cancels against idem in the denominator.Disclaimer: I'm a little out of my depth here - based on memories from student-times long ago. Perhaps @vanhees71 can shed some more didactically responsible light on this ... ?
Well what you have said sounds more reasonable. The integral is given as ##\int_{\-infty}^{\infty}## which is why I said what I did.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
