Cannon Muzzle Velocity Question ( Solved )
In summary, the problem involves a cannon that shoots a cannonball horizontally while mounted in place and then again while mounted on wheels allowing it to recoil. The task is to find the new muzzle velocity in the second situation. Using the equations for momentum and kinetic energy, the solution involves setting the initial kinetic energy equal to the final kinetic energy, and using the equation for momentum to solve for the velocity of the cannon in terms of the velocity of the projectile. Plugging this into the kinetic energy equation, the correct answer is found to be 392.3 m/s.
ChiHawksFan
A cannon that weighs 500 lbs shoots a cannonball horizontally that weighs 20 lbs at 400 m/s while mounted in place so that it does not move. If the same cannon and cannonball are shot in the same way with the cannon mounted on wheels allowing it to recoil, what is the new muzzle velocity?
p=mv
p1=p2
KE= (1/2)mv2
mcvci + mpvpi = mcvcf + mpvpf
Where:
mc= Mass of the cannon, mp= Mass of the projectile, vci= Initial velocity of the cannon, vpi= Initial velocity of the projectile, vcf= Final velocity of the cannon, vpf= Final velocity of the projectile.
I am really quite lost here. I have tried a bunch of stuff, but can't seem to get the answer. I tried finding the velocity of the cannon's recoil and using it to figure out the new muzzle velocity, but I got an answer that was too low. I have also tried using KE1=KE2, but I don't think that that formula is applicable because I don't think that energy is conserved. Thanks for any help!
Actually, I just solved this problem, but I will show my solution incase someone else might find this helpful.
Mass of Cannon = 500 lbs = 226.8 kg, Mass of Projectile = 20 lbs = 9.1 kg, vpi (Initial muzzle velocity) = 400 m/s
First, I calculated the KE of the projectile in the first situation in which the cannon remains stationary.
KE = (1/2)mv2 --------> KE = (1/2)(9.1)(400)2 -------> KE = 728,000 J
Then, I used the equation KE1 = KE2. This is possible because the same amount of energy is used in both situations. However, in the second situation the cannon has recoil, so it moves in addition to the bullet. Due to this, the right side of the above equation will look like this.
KE = (1/2)(mc)(Vc)2 + (1/2)(mp)(vp)2
(mc = Mass of the cannon, mp = Mass of the projectile, vc = Velocity of the cannon, vp = Velocity of the projectile)
Now, we can set our kinetic energy from the first situation equal to the above equation to get: 728,000 = (1/2)(mc)(Vc)2 + (1/2)(mp)(vp)2
After plugging in all of our known values, we are left with: 728,000 = 113.4vc2 + 4.55vp2
The next step is to put vc in terms of vp in order to figure out the muzzle velocity in the second situation.
To do this, I used the equation mcvci + mpvpi = mcvcf + mpvpf
Since nothing is moving before the canon is fired, the initial momentum is 0. This leaves us with 0 = mcvcf + mpvpf
Next, we will plug in our known values to get 0 = 226.8vc + 9.1vp
If we solve for vc, we are left with vc = .04 vp
Now that we have vc in terms of vp, we can plug it into our previous equation 728,000 = 113.4vc2 + 4.55vp2
After we do this, we are left with: 728,000 = .181vp2 + 4.55vp2 --------> 728,000 = 4.731vp2
If we solve for vp, we get that vp = 392.3 m/s, which is the correct answer.
I hope that this helps!
Related to Cannon Muzzle Velocity Question ( Solved )
1. What is cannon muzzle velocity?
Cannon muzzle velocity refers to the speed at which a projectile exits the muzzle of a cannon. It is typically measured in units of meters per second (m/s) or feet per second (ft/s).
2. How is cannon muzzle velocity calculated?
Cannon muzzle velocity can be calculated using the equation v = √(2gh), where v is the velocity, g is the acceleration due to gravity, and h is the height of the cannon's muzzle above the ground.
3. What factors affect cannon muzzle velocity?
Several factors can affect cannon muzzle velocity, including the weight and size of the projectile, the amount of gunpowder used, the angle of the cannon, and air resistance.
4. Why is cannon muzzle velocity important?
Cannon muzzle velocity is important because it determines the range, accuracy, and destructive power of a cannon. It is also a crucial factor in determining the effectiveness of a cannon in battle.
5. Can cannon muzzle velocity be increased?
Yes, cannon muzzle velocity can be increased by using a heavier projectile, increasing the amount of gunpowder, or adjusting the angle of the cannon. However, increasing the muzzle velocity also comes with risks, such as damaging the cannon or reducing its accuracy.
