Cannot isolate y (first order quadratic DE?)
  • MHB
  • Thread starter GreenGoblin
  • Tags
    Quadratic
In summary, the conversation discusses solving two versions of a quadratic first order differential equation, with the first equation given as 1)\frac{dy}{dx}=y - \frac{y^{2}}{10} - 0.9 and the second equation given as 2)\frac{dy}{dx}=y - \frac{y^{2}}{10} - 5. The person in the conversation is confident that if they can solve one version, they can solve the other as it only involves changing one value. The method for solving the equation involves completing the square on the denominator and using either an inverse tangent or logarithmic anti-derivative through partial fractions. The conversation also discusses using an integrating factor to solve the
GreenGoblin
68
I am required to solve two versions of the similar equation for y(x). I think this would be called a quadratic first order differential equation, but I don't even know if that is the correct name:
1)[TEX]\frac{dy}{dx}=y - \frac{y^{2}}{10} - 0.9[/TEX]
2)[TEX]\frac{dy}{dx}=y - \frac{y^{2}}{10} - 5[/TEX]
Confidence exists that if I can do one I can do the other since its just changing one value. Let's try the first.
What I tried:
Dividing through the RHS and multiplying by dx, integrating, I get obviously log of the function times 1/ the derivative of the log = x. BUT, then I don't know how to get the y on its own. Basically, I am used to linear problems only. I don't know how to isolate y here because if I take exponents it gets stuck in there and the whole thing gets messy. I would think this is a pretty common problem that once learned is learned. But I haven't learned it and don't know where to. Can anyone help?
If given an ODE of the form:
$\displaystyle \frac{dy}{dx}=ay^2+by+c$
I would rewrite it as (separating variables):
$\displaystyle \frac{dy}{ay^2+by+c}=dx$
Next, I would complete the square on the denominator on the left, to get either a sum of squares (resulting in an inverse tangent anti-derivative) or a difference of squares (resulting in a logarithmic anti-derivative through partial fractions).
Many times you will get an implicit solution, although in this case you may choose to express $x$ as a function of $y$.
Another option would be to compute an integrating factor, resulting in an exact ODE.
Thanks for your reply, using the method you said I lead to: [TEX]\frac{-1}{10}\frac{dy}{(y-5)^{2}-16}= dx[/TEX]. IS this useful? How can I make it into partial fractions as you say?
Yes, this is correct for the first equation you gave. To simplify a bit, I would use the substitution:
$u=y-5\,\therefore\,du=dy$
and multiply through by 10 to get:
$\displaystyle \frac{du}{4^2-u^2}=10\,dx$
Use the difference of squares formula:
$\displaystyle \frac{du}{(4+u)(4-u)}=10\,dx$
Now, for the integrand on the left, assume the partial fraction decomposition has the form:
$\displaystyle \frac{1}{(4+u)(4-u)}=\frac{A}{4+u}+\frac{B}{4-u}$
Using the Heaviside cover-up method, we find:
$\displaystyle A=B=\frac{1}{8}$ hence:
$\displaystyle \frac{1}{(4+u)(4-u)}=\frac{1}{8}\left(\frac{1}{4+u}+\frac{1}{4-u} \right)=\frac{1}{8}\left(\frac{1}{u+4}-\frac{1}{u-4} \right)$
and now we have:
$\displaystyle \left(\frac{1}{u+4}-\frac{1}{u-4} \right)\,du=80\,dx$
Now integrate, then back-substitute for $u$. In this case you can actually solve for $y$ in the end. Let us know how you progress.:cool:
and now we have:
What you just did is absolutely world class, I am going to work through and get an understanding, see if I get stuck again. Just want to say thanks a lot for now that gives me a lot to go with!
One point: have I not made a mistake with the coefficient -1/10 on the LHS, should it not be -10? Since it is in the denominator.
Assume that we want to solve the differential equation of the form :
$$y'=ay^2+by+c$$
Let us try to solve the right hand side by the quadratic formula :[tex]y=\frac{-b\pm\sqrt{b^2-4ac}}{2a}[/tex]
[tex]y'=(y-\frac{-b+\sqrt{b^2-4ac}}{2a})(y-\frac{-b-\sqrt{b^2-4ac}}{2a})[/tex]
so assume that the roots are
[tex]k_1=\frac{-b+\sqrt{b^2-4ac}}{2a}\,\,\, k_2=\frac{-b-\sqrt{b^2-4ac}}{2a}[/tex][tex]y'=(y-k_1)(y-k_2)[/tex][tex]\frac{dy}{(y-k_1)(y-k_2)}=dx[/tex][tex]\left(\frac{1}{y-k_1}-\frac{1}{y-k_2}\right)dy=dx(k_1-k_2)[/tex]
Now integrate both sides to get :
[tex]\ln\left|\frac{y-k_1}{y-k_2}\right|=(k_1-k_2)x+C[/tex]
Yes, you are right, sorry for missing that.(Tmi)
$$y'=ay^2+by+c$$
What happens when the roots are complex?
Out of curiosity: $y'=ay^2+by+c$ is a separated variables equation and also a Riccati equation. If $k\in\mathbb{R}$ is a solution of the equation $at^2+bt+c=0$ then, $y_1=k$ is a particular solution, and with the substitution $y=y_1+\dfrac{1}{v}$ we get a linear equation on $v$.
At any case (as has been said) is better to solve it by separation of variables.
I haven't considered that. Let me think about it .. :confused:
When the roots of the polynomial are complex, this will require some knowledge of the principle logarithm in complex analysis
[tex]\text{Log}z = \ln|z|+i\text{Arg}(z)[/tex]
Let us assume that we want to find the solution of the differential equation :
[tex]y'=y^2+1[/tex]
Clearly this is separable and can be solved directly ...
[tex]y=\tan(x+C) [/tex]
Now let us prove our method :
[tex]\text{Log}\left( \frac{y-k_1}{y-k_2}\right)=(k_1-k_2)x+C[/tex]
we have that $k_1=i $ and $k_2=-i$
[tex]\text{Log}\left(\frac{y-i}{y+i}\right)=2ix+C_1[/tex]
Now we multiply by the conjugate :
[tex]\text{Log}\left(\frac{(y-i)^2}{y^2+1}\right)=2ix+C_1[/tex]
[tex]2\text{Log}(y-i)-\ln{(y^2+1)}=2ix+C_1[/tex]
[tex]\text{Log}{(y-i)}=\ln \sqrt{(y^2+1)}+i\arctan\left(\frac{-1}{y}\right)=\frac{1}{2}\ln(y^2+1)+i\arctan(y)+C_2[/tex]
[tex]2\left(\frac{1}{2} \ln (y^2+1)+i\arctan(y)+C_2\right)-\ln{(y^2+1)}=2ix+C_1[/tex]
[tex]\ln(y^2+1)+2i\arctan(y)-\ln{(y^2+1)}=2ix+C_3[/tex]
[tex]\arctan(y)=x+C[/tex]
FAQ: Cannot isolate y (first order quadratic DE?)
What is a first order quadratic differential equation?
A first order quadratic differential equation is an equation that contains only one independent variable and its derivatives, with the highest derivative being of degree two. It can be written in the form dy/dx = f(x,y).
Why is it important to isolate y in a first order quadratic differential equation?
Isolating y in a first order quadratic differential equation allows us to solve for y explicitly and find its relationship with x. This is beneficial in understanding the behavior of the system described by the equation and making predictions.
What are the steps to isolate y in a first order quadratic differential equation?
The steps to isolate y in a first order quadratic differential equation are: 1) Rearrange the equation so that the terms involving y and its derivatives are on one side and the remaining terms are on the other side. 2) Factor out the highest derivative term. 3) Divide both sides by the remaining terms. 4) Integrate both sides with respect to x. 5) Solve for y.
Can y always be isolated in a first order quadratic differential equation?
No, y cannot always be isolated in a first order quadratic differential equation. If the equation is nonlinear or does not have a constant coefficient, it may not be possible to isolate y. In such cases, numerical or approximate methods may be used to find a solution.
How is a first order quadratic differential equation used in science?
First order quadratic differential equations are used in many areas of science, including physics, biology, engineering, and economics. They can be used to model real-world systems and predict their behavior. For example, they can be used to describe the motion of a falling object due to gravity or the growth of bacteria in a culture.
