Canonical Transformation of the Hubbard Model
In summary, Atland and Simons say that by choosing the operator \hat{O} such that \hat{H}_t - t[\hat{O}, \hat{H}_U] = 0, all terms at first order in t can be eliminated from the transformed Hamiltonian. As a result, the effective Hamiltonian is brought to the form\hat{H}' = \hat{H}_U + \frac{t}{2}[\hat{H}_t, \hat{O}] + O(t^3)
maverick280857
1,789
Hi,
Suppose we have a 2 site Hubbard model, with the hopping Hamiltonian given by [itex]H_t[/itex] and the Coulomb interaction Hamiltonian given by [itex]\hat{H}_U[/itex]. In the strong coupling limit (U/t >> 1), we define a canonical transformation of [itex]\hat{H} = \hat{H}_U + \hat{H}_t[/itex], as
[tex]H' = e^{-t\hat{O}}\hat{H}e^{t\hat{O}} = \hat{H} - t[\hat{O},\hat{H}] + \frac{t^2}{2}[\hat{O},[\hat{O},\hat{H}]] + \ldots[/tex]
Atland and Simons say (on page 63):
By choosing the operator [itex]\hat{O}[/itex] such that [itex]\hat{H}_t - t[\hat{O}, \hat{H}_U] = 0[/itex], all terms at first order in t can be eliminated from the transformed Hamiltonian. As a result, the effective Hamiltonian is brought to the form
[tex]\hat{H}' = \hat{H}_U + \frac{t}{2}[\hat{H}_t, \hat{O}] + O(t^3)[/tex]
I don't get this. Even if this choice is made,
[tex]\hat{H} - t[\hat{O}, \hat{H}] = (\hat{H}_U - t[\hat{O},\hat{H}_t]) + \underbrace{(\hat{H}_t - t[\hat{O},\hat{H}_U])}_{\mbox{0 by choice}} = \hat{H}_U - t[\hat{O},\hat{H}_t][/tex]
So there's still a t-dependent first order term. What's wrong here?
I would guess that O can be chosen so that it commutes with H_t.
upto first order in [itex]t[/itex]:
[itex] H_U + H_t - t[O,H_U] - t[O,H_t] [/itex] ... (Eq 1)
Now choosing [itex] H_t - t[O,H_U] =0 \Rightarrow H_t = t[O,H_U] [/itex]
Put this back to Eq. 1, and you'll have no order [itex]t[/itex] term left.
How is [itex]H_U - t[O, H_t] = 0[/itex]?
In fact
[tex]H_U - t[O, H_t] = H_U - t[O, t[O, H_U]] = H_U - t^2[O, O H_U - H_U O][/tex]
Are you using some projection property of the O, like [itex]O H_U O = 0[/itex] here?
Don t forget that H_t is already first order in t, so t times it s commutator with O is second order.
Yes, that's what my last post says DrDu. But the [itex]t^2[/itex] term isn't zero -- or at least I don't see it.
Shouldn't the expression in the book then say [itex]O(t^2)[/itex] instead of [itex]O(t^3)[/itex]?
As I understood your first post, the transformed hamiltonian in the book is explicitly written down including all second order terms and the third order terms are abbreviated O(t^3). So yes, there is a second order order term in the transformed hamiltonian but not a first order term any more as you originally claimed.
You don't want it to vanish. All I meant is, by that particular choice of operator [itex]\hat{O}[/itex] your Hamiltonian becomes [itex]H = H_U + \mathcal{O}(t^2)[/itex], which is what you deduce below.
In fact
When written in this way one can see that the [itex]\mathcal{O}(t^2)[/itex] are perturbations about the Hubbard [itex]U[/itex] term, i.e. your original system is a one with all electrons frozen at their lattice sites and then your introduce hopping by the [itex]t[/itex] terms. In fact the [itex]\mathcal{O}(t^2)[/itex] term is the Heisenberg model and represents super exchange which leads to effective spin flips.
Related to Canonical Transformation of the Hubbard Model
1. What is the Hubbard Model?
The Hubbard Model is a simplified model used in condensed matter physics to study the behavior of electrons in a lattice. It takes into account the interactions between electrons and the energy levels of the lattice sites.
2. What is a Canonical Transformation?
A Canonical Transformation is a mathematical technique used to transform a set of variables in a physical system to a new set of variables while preserving the fundamental properties and equations of motion of the system. In the context of the Hubbard Model, it is used to simplify the equations of motion and make it easier to solve.
3. Why is Canonical Transformation used in the Hubbard Model?
The Hubbard Model can become quite complex and difficult to solve, especially in systems with large numbers of particles. Canonical Transformation allows for a simplification of the equations of motion, making it easier to analyze and understand the behavior of the system.
4. How is Canonical Transformation applied to the Hubbard Model?
In the Hubbard Model, Canonical Transformation is typically applied to the Hamiltonian, which represents the total energy of the system. The transformed Hamiltonian is then used to derive equations of motion for the system, which can be solved to obtain information about the behavior of the electrons in the lattice.
5. What are the limitations of Canonical Transformation in the Hubbard Model?
While Canonical Transformation can simplify the equations of motion, it is not always possible to find a transformation that fully simplifies the system. In addition, it may not be applicable to all types of Hubbard Models, and the resulting equations may still be difficult to solve for large systems. As such, other approximation methods may need to be used in conjunction with Canonical Transformation to fully understand the behavior of the system.
