Can‘t call a subroutine name in a subroutine in Fortran90
In summary,The code for example appears to have a problem when it is compiled and executed. Moving the subroutine B out of the 'contains' clause of the interface solves the problem.
pilipili2021
Coding by ifort
Try to call a uncertain name subroutine
NONE
Here is the code for example:
Fortran:
PROGRAM  main
  CALL B()
  CALL CaoB(B)
  contains
  subroutine B()
  IMPLICIT NONE
  write (*,*) 'fk'
  end subroutine B
 subroutine CaoB(fcn)
 implicit none
 INTERFACE
   SUBROUTINE fcn()
     IMPLICIT NONE
   END SUBROUTINE fcn
 END INTERFACE
 write (*,*) '1'
 call B()
 write (*,*) '2'
 call fcn()
 write (*,*) '3'
 end subroutine CaoB
END
Then I compile it.
ifort main.F90
It seems no error. Then run it.
./a.outIt show that
fk
fk
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
a.out 000000000040492A Unknown Unknown Unknown
libpthread-2.31.s 00007F15A65153C0 Unknown Unknown Unknown
Unknown 00007FFFC18B82C0 Unknown Unknown Unknown
Surely there is something wrong when I call the subroutine fcn, which it should be named as B.
So, what should I do? what's wrong? Please let me know if any of you have any ideas or any comments.
thank you
How does the main program know that ?
[edit] Or rather: the calling program, in this case CaoB
Thank you for your reply.
Do you mean add some code like 'external B' or 'external fcn'? That not works.
In the subroutine 'CaoB' it have a subroutine name 'fcn' determined by the interface. When I call 'CaoB(B)', 'B' as a subroutine name should be instead of 'fcn' in the subroutine 'CaoB'. It should be, but something goes wrong.
Your program appears to be fine. I have checked both with GNU Fortran (GCC) 10.2.0 and ifort version 2021.2.0 20210228.
Thank you for your reply!
It's a great help.
May be my environment have some problems.
my ifort version is 2021.4.0
So confused.
It's a great help.
So confused.
Problems are usually fixed with newer versions :smile:.
By the way, my ifort is on Linux.
My ifort is on ubuntu 20.04 , also on Linux.
Everything worked well before my hard disk suddenly broken.
May problems created with newer versions:cry:
finally I find the problem.
If I code like
Call CaoB()
contains
subroutine B()
the error comes.
If I move subroutine B out of 'contains' like
subroutine B()
subroutine something
call CaoB()
end subroutine something
Then the problem is solved.
FAQ: Can‘t call a subroutine name in a subroutine in Fortran90
What is a subroutine in Fortran90?
A subroutine in Fortran90 is a named block of code that can be called multiple times within a program. It allows for the organization and reuse of code, making programs more efficient and easier to maintain.
Can a subroutine call another subroutine in Fortran90?
Yes, a subroutine can call another subroutine in Fortran90. This is known as nested subroutines and allows for more complex and modular programming.
Why am I getting an error message when trying to call a subroutine name in a subroutine in Fortran90?
This error message may be caused by a number of reasons, such as a misspelled subroutine name, incorrect syntax, or attempting to call a subroutine before it is defined. Double check your code and make sure all subroutine names are correct and in the correct order.
Can I pass parameters to a subroutine in Fortran90?
Yes, you can pass parameters to a subroutine in Fortran90. This allows for the subroutine to receive information from the main program and use it in its calculations or operations.
Is there a limit to the number of subroutines I can call within a program in Fortran90?
No, there is no limit to the number of subroutines that can be called within a program in Fortran90. However, it is important to use subroutines efficiently and avoid unnecessary nesting to maintain a clear and organized program structure.
