- #36
- 23,503
- 5,778
For a spherical indenter (drum stick head), the membrane will be in contact with the indenter up to the separation of the membrane from the indenter (at the contact circle at radial location ##r_i##, measured from the vertical axis of the indenter).
If the depth of penetration of the spherical indenter of radius R is large compared to the radius of the contact circle ##r_i##, the slope of the indenter at the separation point will be:
$$slope=\frac{r_i}{R}\tag{1}$$
This must match the slope of the membrane immediately above the contact circle:
$$slope=\frac{\delta}{r_i\ln{(r_0/r_i)}}\tag{2}$$
where δ is the depth of penetration of the indenter.
What do you get if you combine these two equations for the slope?
I also previously presented the following equation for the indenter force:
$$F=\frac{2πσ_ph}{\ln(r_o/r_i)}δ\tag{3}$$
We are going to combine the two slope equations to eliminate ##r_i## and obtain the results for the force in terms of ##\frac{δR}{r_0^2}##
Chet
Chet
