Can't find expression for work done by gravity. Please help.
In summary, the conversation discusses deriving an expression for the work done by gravitational force in moving an object from infinity to a distance 'r' from it. The resulting equation shows a negative value for work done, which is explained by the fact that the direction of gravity is inward and potential energy increases as an object is lifted to infinity. This results in all values of potential energy being negative.
Prem1998
148
Hi, I was deriving an expression for the work done by gravitational force of an object in moving another object from infinity to a distance 'r' from it. I think it should be positive valued because since displacement in this case is in the direction of the gravitational force, so work done by gravity must be positive. But why am I getting a negative valued expression as follows?:
Suppose the masses of the two objects A and B are 'M' and 'm'. Then gravitational force between them when located at a distance 'x' is:
F=GMm/R^2,
suppose B is moved by this force by a small distance dx, then work done by F is:
dW= (GMm/R^2)*dx*cos0 (because dx is in the direction of F)
= (GMm/R^2)*dx
therefore net work done in moving B from infinity to 'r' is:
W= integration[(GMm/R^2)*dx] with upper limit r and lower limit infinity,
= GMm* [-1/R] from infinity to r
= GMm* [-1/r-(-1/infinity)]
= GMm* [-1/r+0]
= -GMm/r
So, why am I getting negative value of work done by gravity even when displacement is in the direction of force?
You are integrating a positive quantity over a range where the initial value is greater than the final value. Of course you are going to get a negative result.
Gravity points inward. Its sign is negative. Multiply it by a positive dx and you should get a negative quantity. Let the fact that you are integrating with inverted endpoints take care of the resulting sign problem for you.
F=GMm/R^2,
Here is the problem. Note that according to this expression F is not a function of x. If you were to write the force in terms of x then it would be F=-GMm/x^2 because F points in the opposite direction of increasing x.
Likes Chestermiller
something else that may help you get to grips with this aspect of physics:- lifting an object increases its potential energy, therefore it has maximum potential energy when it is lifted to infinity.
This is true for all masses so it makes some sense to agree that the zero of potential energy is
at infinity. This means that all values of potential energy are negative.
The potential at the Earths surface is -63 Mj/kg which means that 63Mj of energy must be supplied to each kg to lift it to infinity (escape from the Earth)
Likes dextercioby
FAQ: Can't find expression for work done by gravity. Please help.
How is work done by gravity defined?
The work done by gravity is defined as the force of gravity acting on an object multiplied by the distance the object moves in the direction of the force.
Why is it difficult to find an expression for work done by gravity?
Finding an expression for work done by gravity can be difficult because it depends on factors such as the mass and distance of the objects involved, as well as the strength of the gravitational force.
Can you provide an example of calculating work done by gravity?
For example, if a person lifts a 10 kg object 2 meters off the ground, the work done by gravity would be 10 kg x 9.8 m/s^2 x 2 m = 196 joules.
How does work done by gravity relate to potential energy?
The work done by gravity is equal to the change in potential energy of an object. As an object moves against the force of gravity, it gains potential energy, and as it moves with the force of gravity, it loses potential energy.
Is work done by gravity always negative?
No, the work done by gravity can be positive or negative depending on the direction of the force and the direction of the object's movement. If the force and movement are in the same direction, the work done is positive, but if they are in opposite directions, the work done is negative.
