Can't find the correct power of this circuit -- Please help
In summary: I don't understand! Please can you explain? And why should be both current sources sinking power?In summary, the circuit has been analyzed using Kirchoff's laws and the calculated values for currents and voltages match those obtained from a QUCS simulation. However, there is a discrepancy in the power consumed and produced, which may be due to the current sources sinking power instead of supplying it. This should be addressed in order to get consistent values.
tonlika
This is the circuit:
I have found all the currents and voltages with the Kirchoff's laws. I think they are correct because they perfectly matched the results of a QUCS simulation of the circuit.
I1 = -2.241
I2 = 0.759
I3 = -0.284
I4 = 1.957
I5 = -0.241
I6 = -1.284
V(R1) = I1*R1 = -2.241 * 1 = -2.241 V
V(R3) = I2*R3 = 0.759 * 5 = 3.795 V
V(R4) = I4*R4 = 1.957 * 4 = 7.828 V
V(R5) = I5*R5 = -0.241 * 3 = -0.723 V
V(R6) = I3*R6 = -0.284 * 8 = -2.272 V
V(R7) = I6*R7 = -1.284 * 9 = 11.556 VThis is how I calculated the powers:P(R1) = I12 * R1 = 5.02 W
P(R3) = I2¬¬2 * R3 = 2.88 W
P(R4) = I42 * R4 = 15.32 W
P(R5) = I52 * R5 = 0.17 W
P(R6) = I32 * R6 = 0.65 W
P(R7) = I62 * R7 = 14.84 W
Power consumed = 38.88 WP(E1) = I1*E1 = -2.241 * 8 = -17.93 W
P(E5) = I5*E5 = -0.241 * 15 = -3.62 W
P(E6) = I3*E6 = -0.284 * (-1) = 0.284 W
P(J2) = (V2 - V3)*J2 = (6.514 + 11.556)*3 = 54.21 W
P(J8) = (V4 - 0)*J8 = 2.720 * (-1) = -2.720 W
Power produced = 30.224 W
As you can see the power consumed doesn't equal the power produced.
What am I doing wrong?
Thanks in advance!
I1 = -2.241
I2 = 0.759
I3 = -0.284
I4 = 1.957
I5 = -0.241
I6 = -1.284
Thanks in advance!
Should both current sources be sinking power instead of supplying it? It looks like you have one of them doing that, but not both.
He's asking you a question.
Should a current source be supplying power, or dissipating (sinking) power?
I don't know. The exercise says nothing about it. I guess they should be supplying.
Well think about it, if I have circuit with a source (be it current or voltage) and one resistor, would you expect the source to be supplying power and the resistor sinking power, or vice versa?
Well, I think the source would be supplying power and the resistor sink it.
Good! Now the same thing should apply to your circuit, correct?
Yes, I think.
There was a thread a little while back where how to handle the power balance equations with current sources was discussed. Look for where ideasrule comes into the thread at post #16:
https://www.physicsforums.com/showthread.php?p=3281983&posted=1#post3281983
The current source's power is actually negative. The voltage sources contribute positive power because they take electrons at low potential and raise them to a higher potential, which injects energy into the circuit. On the other hand, the current source takes electrons at high potential and drops them to a lower potential, which uses power for the same reason that a voltage drop across a resistor means the resistor uses power.
You should get consistent values after addressing these two issues.
Wow, I'm fairly certain I remember doing problems similar to this demonstrating that power is conserved throughout the circuit with the current sources supplying power.
In fact my old textbook lists the conservation of power as follows,
[tex]\Sigma P_{sources} = \Sigma P_{other elements} [/tex]
this is listed for both average power and complex power.
Is this incorrect?
Very interesting.
Sorry to the OP if I have been misleading.
I don't know either. As you can tell from that thread, I was confused as well.
For the real circuits that I design, both voltage and current sources supply power. But I kept getting the wrong answers in that other thread...
Ideally, a voltage or current source and dissipate power. Take as an example a resistor with a the positive terminals of a 5v and 10v battery on each side. The voltage source with lower voltage dissipates power (equal to (10-5)/r*5 )
<snip>
I1 = -2.241
I2 = 0.759
I3 = -0.284
I4 = 1.957
I5 = -0.241
I6 = -1.284
I thought I'd analyze the given circuit myself to confirm the current and voltage values. I'm not getting the current values that you've given. Thinking that I might have mucked up the math somewhere, I threw the circuit at a spice simulator. Spice agreed with my calculations.
Is it possible that your values for the currents correspond to a slightly different circuit somehow? Are all the sources in their specified orientations with their specified values?
For the record, the currents that I calculated which correspond to those you've indicated on your diagram:
I1 = -0.448 A
I2 = 2.552 A
I3 = 0.058 A
I4 = 0.505 A
I5 = 1.552 A
I6 = -0.942 A
Perhaps someone else can confirm?
Either ideal sources, both current and voltage, can sink or source power. Think of a battery, it can supply power (discharge) or it can absorb power (recharge).
I1 = -0.448 A
I2 = 2.552 A
I3 = 0.058 A
I4 = 0.505 A
I5 = 1.552 A
I6 = -0.942 A
Thanks for the reply but I solved it. When I calculated the power of the sources I didn't take into account the direction of the current relative to the polarity of the source. Doing that, I found that the total power of all sources is -38.88 W so the problem is solved.
Also I must apologize to you. It is my fault to maybe have created confusion because there is a mistake in the circuits schematics. The node numbered 3 should be where the node number 4 is and vice-versa. Also I forgot to write the voltages of the nodes 1, 2, 3 and 4.
Thanks to all for your time and patience! :smile:
Yes I was thinking that E6 and J8 might have been causing you that particular problem. Remember that there's no law to stop you from reversing the reference polarity and negating the value of a source before you start, if you wish. Personally I always redraw and negate negative valued sources that way. I see this as kind of analogous to carrying a double negative throughout a long an complicated mathematical calculation. If you don't make any mistakes then it shouldn't effect the results, but it still makes a lot more sense to just get rid of any double negative at the get go.
FAQ: Can't find the correct power of this circuit -- Please help
1. What is the purpose of finding the correct power of a circuit?
Finding the correct power of a circuit is important for determining the electrical energy being consumed or produced by the circuit. It also helps in understanding the circuit's behavior and ensuring it is operating within its designed capacity.
2. How do I calculate the power of a circuit?
To calculate the power of a circuit, you can use the formula P=VI, where P is power, V is voltage, and I is current. Alternatively, you can use the formula P=I²R, where R is resistance. Make sure to use the appropriate units for each variable.
3. Why is it important to use the correct power in a circuit?
Using the correct power in a circuit is crucial for preventing overheating and potential damage to the circuit components. It also ensures the circuit is functioning efficiently and safely.
4. What can cause incorrect power readings in a circuit?
Incorrect power readings can be caused by faulty or damaged components, incorrect wiring, or incorrect calculations. It is important to double-check all connections and calculations to determine the source of the error.
5. How can I troubleshoot and find the correct power of a circuit?
To troubleshoot and find the correct power of a circuit, you can start by checking all connections and ensuring they are secure and correct. Then, use a multimeter to measure voltage and current at different points in the circuit. Finally, use the appropriate formulas to calculate the power and compare it to the expected value.
