MHB Cant quite see this grad relation
  • Thread starter Thread starter ognik
    Grad Relation
ognik
Book states: $\nabla f\left(u, v\right) =0 = \frac{\partial f}{\partial u}\nabla u + \frac{\partial f}{\partial v} \nabla v, \therefore \nabla u$ and $ \nabla v $ are parallel
1. I know $d f\left(u, v\right) = \frac{\partial f}{\partial u}du + \frac{\partial f}{\partial v} dv$, but how can we just replace the d<...> by $\nabla <... >$ like that? seems a little circular?
2. Can't anyway see how that makes them parallel?
I get $ =\frac{\partial f}{\partial u}\left( \pd{u}{x}, \pd{u}{y},\d{u}{z}\right) + \frac{\partial f}{\partial v}\left( \pd{v}{x}, \pd{v}{y},\d{v}{z}\right)
= \left( \pd{f}{x}, \pd{f}{y},\d{f}{z}\right) + \left( \pd{f}{x}, \pd{f}{y},\d{f}{z}\right)$ so both tterms are equal and parallel, but why does that make the $\nabla$ parts parallel?
It's a generalization for multiple dimensions.
The chain rule for multiple dimensions says:
$$\d f x = \pd f u \pd u x + \pd f v \pd v x$$
Are they really parallel?
And does $\pd f u \pd u x = \pd f x$ hold?
Let's pick an example.
Suppose we pick $f(u,v)=u^2+v^2-1, \quad u(x,y)=x+y, \quad v(x,y)=x-y$
How would that work out?Oh, and I've moved your thread to Calculus, which is where Partial Derivatives and Multi-variable Calculus belongs.
Please check the descriptions of the forums on the main page.
$$\d f x = \pd f u \pd u x + \pd f v \pd v x$$.
So $ \pd{f}{x}, \pd{f}{y} = \nabla f = \left( \pd{f}{u}\pd{u}{x}+\pd{f}{v}\pd{v}{x}, \pd{f}{u}\pd{u}{y}+\pd{f}{v}\pd{v}{y} \right) = \pd{f}{u} \left( \pd{u}{x},\pd{u}{y} \right) + \pd{f}{v}\left( \pd{v}{x},\pd{v}{y} \right) ...$?
I like Serena said:
Are they really parallel?.
I couldn't see why they should be, but the book says if $\nabla f = 0$, then they are, I can't see this is a general case?
I like Serena said:
And does $\pd f u \pd u x = \pd f x$ hold?.
didn't understand why you asked, its missing the $\pd{f}{v}...$ part?
Thanks, I was honestly undecided 'cos in my book this is a section on vectors, just looking at grad, curl etc...
Correct.
I actually overlooked that it was given that $\nabla f = 0$.
In that case they have to be parallel, since the only way 2 vectors can sum up to zero is if they are equal and opposite.
Since the partial derivatives are only scalars, that implies that one vector must be a multiple of the other. That is, parallel.
It's not true, which should become clear if we work out the example I posted.
If you look at the descriptions of the forums, it should be clear where it should go, regardless of the section in your book.
