Can't solve a sequence (to determine if a given value is a member)
In summary: Without using calculus, to explore the monotonicity of the sequence, I would write the $n$th term as suggested above by Amer:a_{n}=\frac{1}{2}+\frac{1}{2n^2}Can you see that each succeeding term is smaller than the last, and that as $n$ grows without bound $a_{n}$ asymptotically approaches \frac{1}{2}?
theakdad
211
Can somebody help me with this problem? I have to proof if 41/81 is a part of attached sequence. Step by step guide would be useful. Thank you! http://img.tapatalk.com/d/13/10/18/2unyje8y.jpg
Mathematics news on Phys.org
Re: Cant solve a sequence
[tex] a_n = \frac{n^2 +1}{2n^2} [/tex]
[tex]\frac{n^2 +1}{2n^2} = \frac{n^2}{2n^2} + \frac{1}{2n^2} = \frac{1}{2} + \frac{1}{2n^2} [/tex]
can we find "n" such that
[tex] \frac{1}{2} + \frac{1}{2n^2} = \frac{41}{81} [/tex] ?
solve it for n
solve it for n
thank you,but i still don't get it...
I would write:
\(\displaystyle \frac{n^2+1}{2n^2}=\frac{41}{81}\)
Now, cross-multiply and then see if you can find a natural number solution.
MarkFL said:
I would write:
Can you continiue?
And many thanks
andreask said:
Can you continiue?
And many thanks
I would rather help you continue, so that you learn more. :D
What do you get when you cross-multiply? If you are unfamiliar with this method, if you have:
\(\displaystyle \frac{a}{b}=\frac{c}{d}\)
then cross-multiplying, which means to multiply the numerators on each side by the denominators on the other, and then equating both products, will give you:
\(\displaystyle ad=bc\)
It is a kind of shortcut for multiplying both sides by the common denominator of $bd$:
\(\displaystyle \frac{a}{b}bd=\frac{c}{d}bd\)
Canceling, or reducing the fractions, we get:
Can you do this with the equation I gave?
If it a kind of shortcut for multiplying both sides by the common denominator of bd:
Yes,i understand this!
So i think that's my result: 81*(n^2+1) = 82(n^2)
So 41/81 is not a member of my sequence. Am i right?
I would love to learn more about such sequences,do you know some good reference?
And again,thank you!
You have the correct equation:
\(\displaystyle 81\left(n^2+1 \right)=41\left(2n^2 \right)\)
Now, distribute on both sides, then see if you can solve for $n$...
And no, I do not know of any online resources for studying sequences specifically.
81n2+1 = 82n2
1 = 82n2-81nn
1= n2
I don't know i I am right...or what to do...
andreask said:
81n2+1 = 82n2
1 = 82n2-81nn
1= n2
When you distribute the $81$ on the left side, you need to do so to both terms within the parentheses, as follows:
\(\displaystyle 81n^2+81=82n^2\)
Next, subtract $81n^2$ from both sides, and what are we left with?
81 = n2 ??
andreask said:
81 = n2 ??
Yes, good! :D
So, what is the positive root? What is the positive value of $n$?
MarkFL said:
Yes, good! :D
9 of course.
But what have i proved?That 41/81 is a 9th element of sequence?
andreask said:
9 of course.
Yes, you have shown that:
\(\displaystyle a_{9}=\frac{41}{81}\)
Ok,thank you.
i still have three questions:
1. How can i explore the monotonoty of this sequence?
2. How to draw this sequence in coordinate system?
3. Can you show me another sequence solution(similar to mine)? Of course,if you have time...
\(\displaystyle a_{n}=\frac{1}{2}+\frac{1}{2n^2}\)
Can you see that each succeeding term is smaller than the last, and that as $n$ grows without bound $a_{n}$ asymptotically approaches \(\displaystyle \frac{1}{2}\)?
You could plot the first few terms, along with the asymptote.
You could make up another such problem just as easily as I can. :D
Seems I am to stupid for sequences...
No, that's not the case at all...let's look at the $n$th term:
And let's for now just look at this part of the $n$th term:
\(\displaystyle \frac{1}{2n^2}\)
Would you agree that when the numerator of a fraction is fixed, that is remains constant, and the denominator gets bigger and bigger, then the value of the fraction is getting smaller and smaller?
Yes,i agree!
I think that this sequence is limited too 0,5, but i don't know how to prove it...i have started a master degree with 38,my math was very good at high school,but now...now is all at higher level,i really don't know how would i master this all things...
andreask said:
Yes,i agree!
What does \(\displaystyle \frac{1}{2n^2}\) approach as $n$ grows without bound?
1/2 ?
I really don't know how to get it...
And i really apreciate that you have time for me,thank you
andreask said:
1/2 ?
Let's look at the first few term of this fraction...let:
\(\displaystyle b_{n}=\frac{1}{2n^2}\)
We find:
\(\displaystyle b_1=\frac{1}{2(1)^2}=\frac{1}{2}\)
\(\displaystyle b_2=\frac{1}{2(2)^2}=\frac{1}{8}\)
\(\displaystyle b_3=\frac{1}{2(3)^2}=\frac{1}{18}\)
\(\displaystyle b_4=\frac{1}{2(4)^2}=\frac{1}{32}\)
\(\displaystyle \vdots\)
\(\displaystyle b_{1000}=\frac{1}{2(1000)^2}=\frac{1}{2000000}\)
\(\displaystyle b_{1000000}=\frac{1}{2(1000000)^2}=\frac{1}{2000000000000}\)
Do you see that as $n$ gets bigger and bigger, $b_{n}$ gets smaller and smaller? If we could let $n$ go to infinity, then what would $b_{n}$ be?
We find:
I think that bn would be zero,or very close.
but beacuse of + 1/2 bn can't be smaler then 0,5. Am i right?
And sorry,i have to learn to write fractions etc. in right form.
Yes, $b_{n}$ gets closer and closer to zero, and since:
\(\displaystyle a_n=\frac{1}{2}+b_n\)
then \(\displaystyle a_{n}\) gets closer and closer to \(\displaystyle \frac{1}{2}\).
Does this make sense?
Yes,it makes sense ,of course. Only problem si,how to write this in a proper way for my profesor? :pAnd why is \(\displaystyle \frac{n^2+1}{2n^2}\) equal to \(\displaystyle \frac{1}{2} + \frac{1}{2n^2}\) ?
A property of fractions is that:
\(\displaystyle \frac{a+b}{c}=\frac{a}{c}+\frac{b}{c}\)
so that:
\(\displaystyle \frac{n^2+1}{2n^2}=\frac{n^2}{2n^2}+\frac{1}{2n^2}=\frac{1}{2}+\frac{1}{2n^2}\)
so that:
Now i see...and understand.
Only thing that's left,how to write it on the paper,so that would be acteptable for my teacher...
I owe you a drink now :D
From what course is this problem? If it is for a course prior to calculus, then you will simply need to explain it as best you can in your own words. You could also choose to write the $n$th term as:
\(\displaystyle a_{n}=\frac{1+\frac{1}{n^2}}{2}\)
Now it is easy to see that the denominator is fixed, and the numerator is getting smaller and smaller as $n$ gets larger and larger, that is, the sequence is strictly decreasing, i.e., it is monotonic.
Its prior to algebra...
I will try to do somehow...
I would think the argument I gave in my post previous to this would suffice then.
  • #31
I agree...
But,now i have new problem,about Mathematical induction,should i open new Thread?
  • #32
andreask said:
I agree...
Yes, and I would post it in our Discrete Mathematics sub-forum.
  • #33
I will...
Maybe you can take a look...if you want...
  • #34
I still have one question...What kind of type this sequence is? Arithmetic or geometric? I can't figure it out...
  • #35
An arithmetic sequence has the property:
\(\displaystyle a_{n+1}-a_{n}=d\)
While a geometric sequence would have the property:
\(\displaystyle \frac{a_{n+1}}{a_{n}}=r\)
Note: Both $d$ and $r$ are constants that do not depend on $n$. Does this sequence satisfy either property?
