Capacitance 1/4 correct need b,c,d
  • Thread starter hitman0097
  • Tags
    Capacitance
Remember to always try to understand the underlying principles and concepts rather than just memorizing equations. It will help you solve problems more easily and efficiently.
hitman0097
31
V=8.8V
(a) Find the equivalent capacitance between the terminals
Answer= .242uF
b.) Find the charge stored on the positively charged plate of each capacitor?
C1=.3uF , C2=1uF , C3= .25uF
So I have to find the charge on each plate of the three
c.)Find the voltage across each capacitor?
Same deal but with voltage
d.) Find the total stored energy?
U=1/2*Cep*V
U=1/2 (.242)* 8.8^2
U=9.37uJ
Cep= Q/V=(Q1+Q2+Q3)/V= C1+C2+C3
CV=Q
I tried CV=Q with V=8.8V and my answers for .3uF=2.64uC, 1uF=8.8uC, .25uF=2.2uC
all wrong... I tried to think of C2 and C3 in a parallel Combo where there net capacitance is 1.25uF=Q/8.8V wrong for that too. I've only tried b because I thought V=8.8V was the potential and it was going to be constant but I guess not.
Maybe you could use one of Kirchhoff's laws?
hitman0097 said:
V=8.8V
Answer= .242uF
U=1/2*Cep*V
U=1/2 (.242)* 8.8^2
U=9.37uJ
CV=Q
The method you need to use is as follows:
1) Calculate total capacitance . Ct = 1/((1/c1)+(1/(c2+c3))
2) Find charge on Ct at given voltage. q = C*V
3) Find potential V1 on C1 at charge: V = C/q
4) Subtract V1 from V to find voltage on C2 and C3: V2 = V3 = (V-V1)
5) Now find charge on C2 and C3 by q = q=C*V
hitman0097 said:
V=8.8V
Answer= .242uF
U=1/2*Cep*V
U=1/2 (.242)* 8.8^2
U=9.37uJ
CV=Q
The thing to realize is that an electric current represents an amount of charge moving through a circuit. For every electron which goes into a series circuit, there is an electron which comes out the other end. So in a series circuit like the series of 2 capacitors in your problem (the parallel caps are 1 cap for the purposes of this remark) the same charge is displaced on both cap.
Then you can deal with the parallel circuit of C2 and C3. The potential must always be the same on each capacitor, if potential were different you could expect current to flow until the potentials were equalised.
Don't worry it all becomes second nature once you've done all the homework and sat an exam or 2.
nice that worked and made sense thanks man
you're welcome
FAQ: Capacitance 1/4 correct need b,c,d
What is capacitance?
Capacitance is the ability of a system to store an electric charge. It is measured in units of Farads (F) and is determined by the geometry and material properties of the system.
What does "1/4 correct need b,c,d" mean in relation to capacitance?
"1/4 correct need b,c,d" is a shorthand notation used to represent a parallel plate capacitor with specific dimensions and material properties. The "1/4 correct" refers to the fact that the capacitor is only partially filled with dielectric material, while "need b,c,d" indicates the specific dimensions and material properties needed for the capacitor.
How is capacitance calculated?
Capacitance is calculated by dividing the electric charge stored in a system by the voltage difference across it. This can also be expressed as the ratio of the electric field strength to the potential difference.
What factors affect capacitance?
The capacitance of a system is affected by the geometry of the system, the distance between the plates, the type of dielectric material used, and the permittivity of the material. It is also dependent on the voltage applied to the system.
What are some common applications of capacitance?
Capacitance has a wide range of applications, including in electronic circuits, power transmission and distribution, energy storage, and sensing devices. It is also used in various technologies such as touch screens, capacitive sensors, and radio frequency identification (RFID) systems.
