Capacitance between human body and ground
In summary, a voltage tester (that looks like a screwdriver) will glow brightly even when you are heavily insulated from the ground, like sitting on a wooden chair. This is probably due to the capacitance between the human body and the ground, which is tiny. Safety shoes protect you from larger currents, but the tiny current was sufficient to make the tester glow quite brightly.
QwertyXP
66
Why does a voltage tester (that looks like a screwdriver) turn on even when you are "heavily" insulated from the ground e.g. sitting on a wooden chair.
Is it the result of capacitance between the human body and the ground? (i.e. the body and the ground act as conductors, whereas the insulated gap between them behaves as a dielectric does in a capacitor.)
If capacitance can cause the tester to glow, how then do insulated/EH (electrical hazard) safety shoes work? I don't have those shoes yet so didnt get the chance to use a tester while wearing them. But I was wondering why capacitance doesn't cause current to flow through the human body when wearing those shoes?
The capacitance is "human body against everything else" - floor, walls, ceiling, whatever is in the room (and even in free space, a body has a capacitance).
The capacitance is tiny, and therefore the currents are tiny as well. Safety shoes protect you from larger currents.
But the tiny current was sufficient to make the tester glow quite brightly - about as bright as you see when you're standing on ground with no shoes!
It's a bit hard to help you answer this question without a lot more information about your test situation. Can you post what tester you were using, and what exactly were the test situations you tried (Where did it not light up, where did it light up, etc.)?
Such testers that I've seen include a high ohm resistor that limits the current to less than you can feel. It also protects the neon lamp.
I think the one the OP means does not even use metal to metal contact. I used to have one. Lost track of it for a while and now it does not work. Soooooo, it was rather pointless to start with. If I can't trust it to light up then why would I trust a new one?
yup likewise Jim and sounds like what the OP is describing
Haven't owned one for years but they are effective :)
With the high resistance in the screwdriver tester body and the high resistance of the person to ground via shoes and sox there's still enough current to light the neon globe
cheers
Dave
You can get some visible light with 1mW. At 100 V, that corresponds to 10µA. Below 1mA, it is hard to feel a current, so we have a safety factor of two orders of magnitude.
To get 10µA over 10ms (50 Hz, similar value for 60 Hz) with 100V, you just need 100nC or a capacitance of ~1nC. Give or take a factor of two as I did not do this calculation properly, this is a small capacitance value.
To get the same as DC current, you need a corresponding resistor of 10MOhm. Regular shoes, the floor, and various other objects have a higher resistance, so DC current is probably negligible.
Related to Capacitance between human body and ground
What is capacitance between human body and ground?
Capacitance between human body and ground refers to the ability of the human body to store electrical charge when in contact with the ground.
Why is capacitance between human body and ground important?
Capacitance between human body and ground is important because it can affect the safety of individuals when working with electrical equipment. It can also impact the accuracy of certain electrical measurements.
How does the capacitance between human body and ground affect electrical shock?
The capacitance between human body and ground can increase the risk of electrical shock by allowing for a larger amount of charge to flow through the body. This can be especially dangerous if the body is in contact with a high voltage source.
What factors can affect the capacitance between human body and ground?
The capacitance between human body and ground can be affected by the surface area of the body in contact with the ground, the distance between the body and the ground, and the dielectric properties of the materials in contact.
How can capacitance between human body and ground be measured?
Capacitance between human body and ground can be measured using a capacitance meter, which measures the amount of charge stored on the body when in contact with the ground. It can also be calculated using the formula C = Q/V, where C is capacitance, Q is charge, and V is voltage.
  • Electrical Engineering
  • Electromagnetism
80K
15K
25K
