Capacitance in concentric shells
  • Thread starter Thread starter OptimusPwn
    Capacitance
The discussion revolves around calculating the total capacitance of a system with four concentric spherical metal shells of varying radii, where the two inner shells are connected by a wire. The approach involves assuming a charge +Q on the inner sphere and using Gauss's law to determine the electric field between the shells. The user expresses confusion about integrating to find the potential difference and whether to integrate the electric fields or distances. Responses indicate that the electric fields provided are incorrect and emphasize the need to focus on the regions between the spheres rather than applying V=Ed directly. Clarification on the relationship between electric field and potential difference is suggested for better understanding.
OptimusPwn
Consider four concentric spherical metal
shells of radii r, 2r, 3r, and 4r. The middle
two shells are connected by wire, as shown.
What is the total capacitance of the system?
In your solution, clearly explain your method.
u= 1/2cv^2
So my teacher told us to assume we can hook it up to a battery(voltage) and that the two inner shells have the same charge and to evaluate the potential inner to outer, but I have no idea how to do this.
There's a number of details you'll have to figure out for yourself, but here's generally how to approach the problem. Assume there is a charge +Q on the inner sphere. Use Gauss's law to calculate the electric field between the spheres. You'll have to figure out what the charge of the other spheres as well. Once you know the electric field, you can integrate it to calculate the potential difference between the spheres.
So when I do that I get
E(r)= Q/4(pi)(R)2Epilsonknot
E(2r)=Q/4(pi)(2R)2Epilsonknot
E(3r)=Q/4(pi)(3R)2Epilsonknot
E(4r)=Q/4(pi)(4R)2Epilsonknot
Then I use V=Ed so I integrate this?
What am I integrating though, the difference between the electric fields or the distance?
I am stuck beyond this point and are my electric fields right?
I think you need to go back and review how the electric field and potential difference are related (beyond just plucking formulas out of the book) and then reread my previous post.
Your electric fields are not correct. You want the electric field for the regions between the spheres. Also, you can't use V=Ed here.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
