Capacitance of infinitely long coaxial cylinders of elliptical section
The discussion focuses on the capacitance of infinitely long coaxial cylinders with elliptical cross-sections, where an inequality for capacitance has been established but the exact value remains elusive. A user has referenced a paper that discusses confocal ellipses and suggested using the Joukowski conformal transformation to simplify the problem by mapping ellipses to disks. This transformation allows for the computation of capacitance in a cylindrical symmetric manner. The conversation emphasizes the need to equate real and imaginary parts to derive relationships between the parameters involved. The discussion concludes with a recommendation to define a scale for the problem to facilitate calculations.
Rlwe
Find the capacitance per unit length between two infinitely long coaxial cylinders of elliptical section given by eqs. $$\frac{x^2}{a_1^2}+\frac{y^2}{b_1^2}=1$$ $$\frac{x^2}{a_2^2}+\frac{y^2}{b_2^2}=1$$ where $$\frac{a_2}{a_1}=\frac{b_2}{b_1}$$ and $$b_1\geq a_1\,,\quad b_2\geq a_2\,,\quad a_2>a_1$$
Laplace equation in 2D
I've been able to prove the following inequality $$\frac{2\pi\epsilon_0}{\log\left(\frac{b_1b_2}{a_1^2}\right)}\leq C \leq \frac{2\pi\epsilon_0}{\log\left(\frac{a_1a_2}{b_1^2}\right)}$$ but have no clue how to obtain exact value. Can someone check whether this inequality is correct and show how to obtain the exact value?
Please show us your work.
Sorry, it isn't really a homework (maybe I shouldn't have posted it under HW help, sorry) but a problem I invented. I found this paper (p.10) which deals with a system of confocal ellipses and uses special system of coords to solve it. However, I couldn't find any reference that deals with similar ellipses.
It is still schoolwork-like, so you did the right thing to post it in the schoolwork forums. :smile:
I suggest you use the Joukowski conformal transformation to map ellipses in the ##z## plane (##z=x+iy##) to disks in the ##w## plane (##w=u+iv##), then compute the capacitance in the ##w## plane with cylindrical symmetry (not hard). The Joukowski transformation is,
z=\alpha w + \frac{\beta}{w}
z_{1,2}=x_{1,2}+iy_{1,2}=\alpha_{1,2} (u_{1,2}+iv_{1,2}) + \beta_{1,2} \frac{u_{1,2}-iv_{1,2}}{R_{1,2}^2}
where ##R_{1,2}## are the radii of the disks in the ##w## plane. Equating real and imaginary parts, the equation ## u^2_{1,2} + v^2_{1,2}=R^2_{1,2}## becomes,
\frac{x^2_{1,2} }{\alpha_{1,2} + \frac{\beta_{1,2} }{R^2_{1,2}}} +\frac{y^2_{1,2} }{\alpha_{1,2} - \frac{\beta_{1,2} }{R^2_{1,2}}}=1
where,
a_{1,2}=|\alpha_{1,2} + \frac{\beta_{1,2} }{R^2_{1,2}} |
b_{1,2}=|\alpha_{1,2} - \frac{\beta_{1,2} }{R^2_{1,2}} |
You will have to choose a scale for your problem i.e. ##a_2=\gamma a_1## and ##b_2=\gamma b_1##. From this and the given conditions and constraints you can compute the ratio ##\frac{R_2}{R_1}##.
Likes vanhees71 and berkeman
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
