Capacitor Lab - Charging/Discharing Paths
In summary, the conversation discussed a lab that involved calculating charging and discharging time constants for a circuit. The results from the calculations were compared to the measurements taken in the lab and were found to be different. There was a discussion about the formulas for the time constants and it was determined that the formula for the charging time constant needed to be adjusted to account for the diode in the circuit.
verd
146
I performed a lab this past week that went over charging/discharing time constants, and I was asked the following about the circuit below:
http://synthdriven.com/images/deletable/EEN204-Lab3.jpg
Calculate the charing time constant, (Tau_c), and the discharging time constant, (Tau_d). I was asked to them compare these results with those that I measured in the lab, for three instances. (C=0.1uF)
Instance #1)
R1=470
R2=470
I measured:
Tau_c = 52.76us (<-us=microseconds)
Tau_d = 16 us
Instance #2)
R1=1k
R2=470
I measured:
Tau_c = 35.18us
Tau_d = 35.18us
Instance #3)
R1=470
R2=1k
I measured:
Tau_c = 24us
Tau_d = 48usAs far as the both the time constants went, I came up with the following formulas:
Tau_c=(Rs+R1)C
Tau_d=R2C
And these are my calculations:
Instance 1:
Tau_c = 52us
Tau_d = 47us
Instance 2:
Tau_c = 105us
Tau_d = 47us
Instance 3:
Tau_c = 52us
Tau_d = 100us
These results from the calculations are very different from what I measured in the lab. So something must be incorrect. We measured the time constants by setting up the circuit as shown (I'm 99% certain that the circuit we set up was correct), and measuring the voltage via an oscilloscope hooked up to a computer... That way, we were able to freeze the curve and perform precise calculations with the cursor on the oscilloscope. We were asked to reproduce the curves by hand to turn in with our reports. And by looking at those graphs now, the values the computer gave us for the time constants look to be correct... By the behavior of the curve on the graphs anyway.So I'm writing because I figure that the error is in the formula I put together about the charging/discharging paths. I must be calculating the wrong thing because I probably set the equation up incorrectly.
Could someone tell me if the equations I derived for Tau_c and Tau_d are correct according to the figure?Thanks!
Heather
Your charging time constant looks wrong.
As the voltage across the capacitor increases, an increasing amount of current will flow through R2 instead of charging the capacitor, so the charging rate will be slower than if R2 was not in the circuit. Therefore, the correct formula will have R2 in it as well as (R1+RS).
The discharging time constant is OK, because the diode blocks any current through Rs and R1
My thought concurs with AlephZero and I believe the expression for the charging time constant is ((R1+Rs)||R2)C.
Maybe I should have just gone with "different" in my previous post, not "slower" :rolleyes:
You are right. If you removed the diode, the discharge time constant would obviously be C(R2||(R1+Rs)). The charging time constant must be the same as that, because the diode doesn't affect the charging time constant.
FAQ: Capacitor Lab - Charging/Discharing Paths
What is a capacitor?
A capacitor is an electronic component that stores electrical energy in an electric field. It consists of two conductors separated by an insulating material, known as a dielectric.
How does a capacitor work?
When a voltage is applied to a capacitor, one plate becomes positively charged and the other becomes negatively charged. This creates an electric field between the plates, which stores energy. The capacitor can release this stored energy when needed.
What is the purpose of the "charging path" in a capacitor lab?
The charging path in a capacitor lab allows for the capacitor to be charged with a specific voltage. This allows for the capacitor to store energy and be used in various electronic circuits.
Why is it important to discharge a capacitor before handling it?
A charged capacitor can hold a dangerous amount of electrical energy. Discharging it before handling it is important to ensure safety and prevent electric shocks.
What factors affect the charging and discharging of a capacitor?
The time it takes for a capacitor to charge and discharge depends on the capacitance of the capacitor, the voltage applied, and the resistance in the charging or discharging path. The type of dielectric material used in the capacitor also affects its charging and discharging capabilities.
