Capacitor+work energy theorem problem
In summary, the work-energy theorem can be applied to a capacitor by considering the energy stored in the electric field between its plates. This energy can be calculated using the capacitance and the potential difference across the capacitor. When the capacitor is charged or discharged, work is done on or by the capacitor and the change in energy can be calculated using the work-energy theorem. This principle is useful in understanding the behavior of capacitors in circuits and can be used to solve problems involving capacitor energy.
Krushnaraj Pandya
73
Plate a of a parallel-plate, air filled capacitor is connected to a spring having force
constant k, and plate b is fixed. They rest on a table top.If a charge +Q is placed on plate a and a charge −Q is placed on plate b, by how
much does the spring expand?
All applicable
I have already solved this and the answer is q^2/2k(epsilon)A by equating forces at equilibrium. I now wish to solve this using work energy theorem also. The work done is F*s=Q*E*s=Q^2 x/2(epsilon) where x is extension. Change in potential energy of spring is 1/2 kx^2 and change in electrostatic potential energy is -kq^2/x^2; am I wrong somewhere?
Using forces is the way to go. One must assume that equilibrium is achieved.
Realize that if you try to use energy methods, the work done by the field (to get to the equilibrium point) is more than the work done by the spring, so there is excess energy.
This is similar to the problem of hanging a mass on a spring. When you hang the mass, how much does the spring stretch? The equilibrium point is one answer, found by force methods. But that assumes you gently lowered the weight onto the spring. But what if you just let the weight fall? It will overshoot the equilibrium point. (And oscillate about it.)
the original question mentions that charges are given to both plates very slowly, can we use energy methods now?
That is equivalent to lowering the mass onto the spring gently to the equilibrium point.
So, force balance is the way to go. Realize that the plates will always be in equilibrium if the charges are added slowly. (The force from the field is not constant.) So if you want, you can try calculating the work done and using energy methods. But setting the final forces equal is the easy way.
Alright, I probably shouldn't think of more complicated things when the answer is easily available through force. Thank you very much.
BUT, suppose you have already calculated the extension of the spring, and then they ask you to calculate the work of the electric field during the extension process. What would you answer (I know this is a kind of silly tricked question hehe).
CWatters said:
The equation for the work needed to move the plates under constant voltage is derived in here. See eqn..
https://arxiv.org/ftp/arxiv/papers/1209/1209.6301.pdf
Ok fine, but wouldn't the work of the E-field also equal the increase in the potential energy of the spring?
1)I suppose work done by spring+work done by E-field=increase in potential energy of spring + decrease in potential energy of system of two plates
2)work done by spring is -0.5kx^2,
3) we don't know W by E-field but I thought it should be F*s=Q*E*s=Q^2*x/2A(epsilon) where x is extension and A is area of plate. ( since E is constant)
4)increase in potential energy of spring is 0.5kx^2
5) and decrease in potential energy- since change in electrostatic potential=E*(extension)=change in potential energy/q. Therefore decrease is E*x*q. We can put E as Q/A2(epsilon) if we so wish
Am I wrong anywhere?
The field is not constant, since charge is added slowly.
oh, right...I totally forgot about that. So except 3) and 5), are the other parts correct. And how would we go about it now? It seems quite complicated...
How did you get this?
I guess I'd write the equations I numbered, except 3) and 5) since they're apparently wrong. I don't know how else we can do this...
The way I understand your 1) step above is -W+W=W-W=0, that is since the charge is added slowly, the force from the spring is at any instant of time equal and opposite to the force of the electric field. So the work of electric field is minus the work of the force of the spring that is ##-1/2kx^2##.
And also the increase in potential energy of the spring equals minus the work of the force of the spring, and the decrease of the potential energy of the plates equals the work of the e-field.
Ohh, I see
that'd imply this and it'd also imply ##-1/2kx^2##. is equal to change in electric potential energy...how can we write the RHS of the equation?
Ohh, I see
is it just the energy stored by capacitor = 1/2 QV?
Yes!.
Likes Krushnaraj Pandya
Delta² said:
Yes!.
ohh, ok! I got it, thank you very much for expanding my knowledge by twisting the question...
Likes Delta2
Related to Capacitor+work energy theorem problem
1. How do capacitors store energy?
Capacitors store energy by creating an electric field between two conductive plates separated by an insulating material. When a voltage is applied, electrons are attracted to one plate and repelled from the other, creating a potential difference and storing energy in the form of an electric field.
2. How does the work energy theorem apply to capacitors?
The work energy theorem states that the work done on an object is equal to the change in its kinetic energy. In the case of a capacitor, the work done to charge the capacitor is equal to the change in electrical potential energy, as the stored energy is equal to the product of capacitance and voltage squared.
3. What is the formula for calculating the work done on a capacitor?
The work done on a capacitor can be calculated using the formula W = 1/2 * C * (Vf^2 - Vi^2), where W is the work done, C is the capacitance, Vf is the final voltage, and Vi is the initial voltage.
4. How does the work energy theorem help in solving capacitor problems?
The work energy theorem provides a useful tool for solving capacitor problems by relating the work done to the change in energy. This allows us to calculate the work done on a capacitor and use it to determine the final energy stored in the capacitor.
5. Can the work energy theorem be applied to other electrical components besides capacitors?
Yes, the work energy theorem can be applied to any electrical component that stores energy, such as batteries, inductors, and resistors. It can also be applied to mechanical systems, such as springs and pulleys, to calculate the work done and energy stored.
