Capacitors in paralell disconnected then connected to each other
  • Thread starter Thread starter Staple Gun
    Capacitors
Capacitors C1 (5.95 μF) and C2 (1.90 μF) were initially charged in parallel across a 277 V battery and then disconnected. When reconnected with opposite polarities, the total charge remains constant, but the charges redistribute due to differing capacitances. The charge on C1 was calculated as Q1 = 2.14 x 10^-8 C, while C2 had a charge of 6.859 x 10^-9 C. The voltage across both capacitors must be equal after reconnection, leading to a new charge distribution. Understanding the principles of charge conservation and voltage equality is crucial for solving such capacitor problems.
Staple Gun
Capacitors C1 = 5.95 μF and C2 = 1.90 μF are charged as a parallel combination across a 277 V battery. The capacitors are disconnected from the battery and from each other. They are then connected positive plate to negative plate and negative plate to positive plate. Calculate the resulting charge on capacitor C1.
Q=C/V
This is as far as I got, but I'm guessing I went wrong somewhere.
Calculate equivalent capacitance
Ct = C1 + C2 = 7.85μF
Calculate total charge on the capacitors
Qt = Ct/V = 0.002174 C
Charge on C1 is half of the total, or 0.001087 C
Calculate voltage on C1
V1 = Q1/C1 = 182.7 volts
I am stuck from here though, even if what I've done so far is right, I have no idea where to go.
Calculate the original charge on each capacitor.
When those capacitors are reconnected, what happens to the charge on them? How does the charge rearrange itself? Hint: Consider the total charge and the fact that they are reconnected in parallel.
Thanks for the reply, I am still a bit confused though. I thought the original charge on each capacitor would be half of the total charge of the equivalent capacitor.
Therefore Qt = (C1 + C2)/V
And the charge of each capacitor would be 1/2 Qt
Am I on the right track so far?
This is your mistake. The capacitors have different capacitances! They will have different charges. (Q=C*V). They "have" the same voltage, when in parallel.
Ok, so the charge on capacitor C1 would be...
Q1 = 5.95μF/ 277 V = 2.14*10-8C
and likewise the charge on C2 would be 6.859*10-9C
I really don't have a clue what happens when they are reconnected though.
My guess is that by using Q=CV I can take the sum of the charges, and then using the capacitance of both I can figure out the new electric field across the capacitors, and somehow find the new charge?
Thanks for the help so far! This is for an online class so I never really learned the concepts behind capacitors and I'm struggling to wrap my head around it, but this is helping a lot.
You are mixing up your formulas:
C = Q/V so: Q = CV (not C/V)
Two hints:
(1) When reconnected, the charges rearrange but the total charge can't change.
(2) When reconnected, the voltage across each must be the same.
EDIT: I figured it out, thanks so much for the help!
14K
  • · Replies 18 ·
