Capacitors in series with dielectrics
In summary: The energy density is given by:##u = \frac{1}{2} \kappa \epsilon_0 E^2 = \frac{1}{2} (8)(8.85 \times 10^{-12} \frac{F}{m}) (6.934 \times 10^{7} \frac{V}{m})^2 = 170204.455 \frac{J}{m^3} = 170000 \frac{J}{m^3}## In summary, a 240 nF capacitor and a 4.0 μF capacitor are connected in series with a 240 V potential difference. The 4.0 μF capacitor has a parallel plate configuration with a
STEMucator
2,076
140
A ##240 nF## capacitor and a ##4.0 \mu F## capacitor are connected in series with a ##240 V## potential difference.
The ##4.0 \mu F## capacitor has a parallel plate configuration, with a surface area of ##110 cm^2## and a dielectric material between the plates. The dielectric constant is ##\kappa = 8##.
1. Calculate the charge stored in the ##4.0 \mu F## capacitor.
2. Calculate the potential across the ##4.0 \mu F## capacitor and the potential across the ##240 nF## capacitor.
3. Find the spacing between the plates of the ##4.0 \mu F## capacitor.
4. Find the magnitude of the electric field in the ##4.0 \mu F## capacitor.
5. Calculate the energy density in the ##4.0 \mu F## capacitor.
##C_1 = 4.0 \mu F = 4.0 \times 10^{-6} F##
##C_2 = 240 nF = 240 \times 10^{-9} F##
##V = 240 V##
##\kappa = 8##
##q = CV##
##C = \epsilon_0 L##, where ##L## has the dimension of length.
Screenshot of how I figure the circuit looks: http://gyazo.com/6c138b176e22538339aa4ab44b899b50
For series capacitors: ##C_{eq} = (\sum_{i=1}^{n} \frac{1}{C_i})^{-1}##
1. I'm slightly confused about how to factor in the dielectric material.
A potential is maintained across the circuit and a dielectric is filling the space between the plates of ##C_1##. So the effect of the dielectric is to increase the charge ##q_1## on ##C_1##, by increasing ##C_1## by factor of ##\kappa##?
Using this logic, I could find an equivalent capacitance ##C_{12}## given by:
##C_{12} = ( \frac{1}{\kappa C_1} + \frac{1}{C_2} )^{-1}##
Then using ##q_{12} = C_{12} V_{12}##, I could find the charge across ##C_{12}##.
Then using the fact that capacitors in series all have the same charge, we could write ##q_{12} = q_1 = q_2##.
Does this seem reasonable?
No, you're given ##C_1##. That's the capacitance with the dielectric already factored in.
You need the dielectric constant to answer 3-5, which have to do with the internals of the capacitor.
Likes 1 person
You need the dielectric constant to answer 3-5, which has to do with the internals of the capacitor.
Ah I was a bit confused about that. Thank you for you input.
1. An equivalent capacitor is given by:
##C_{12} = ( \frac{1}{C_1} + \frac{1}{C_2} )^{-1} = ( \frac{1}{4.0 \times 10^{-6} F} + \frac{1}{240 \times 10^{-9} F} )^{-1} = 2.2642 \times 10^{-7} = 2.3 \times 10^{-7} F##
The charge on this capacitor is given by:
##q_{12} = C_{12} V_{12} = (2.2642 \times 10^{-7} F) (240 V) = 0.000054 = 5.4 \times 10^{-5} C##
Since the capacitors are in series ##q_1 = q_2 = q_{12}##.
Continuing the work here:
2. To obtain the potential across ##C_1##, simply use:
##q_1 = C_1 V_1 \Rightarrow V_1 = \frac{q_1}{C_1} = \frac{5.4 \times 10^{-5} C}{4.0 \times 10^{-6} F} = 13.5 V = 13 V##
To obtain the potential across ##C_2##:
##q_2 = C_2 V_2 \Rightarrow V_2 = \frac{q_2}{C_2} = \frac{5.4 \times 10^{-5} C}{240 \times 10^{-9} F} = 225 V = 230 V##
My results seem to be slightly off, not sure why. They should add up to ##240 V##.
3. To find the spacing between the plates of ##C_1##, simply use the general equation for a capacitor with a dielectric:
##C_1 = \kappa \epsilon_0 L = \kappa \epsilon_0 \frac{A_1}{d_1}##
Hence: ##d_1 = \kappa \epsilon_0 \frac{A_1}{C_1} = (8)(8.85 \times 10^{-12} \frac{F}{m}) \frac{0.011 m^2}{4.0 \times 10^{-6} F} = 1.947 \times 10^{-7} m = 1.9 \times 10^{-7} m##
4. Using Gauss' law with a dielectric and noting the electric field is constant between the plates:
##q_1 = \epsilon_0 \oint \kappa \vec{E} \cdot d \vec{A} = \kappa \epsilon_0 \oint \vec{E} \cdot d \vec{A} = \kappa \epsilon_0 E \oint dA## (Since ##\vec{E} \cdot d \vec{A} = E cos(0°) dA##).
The closed surface integral now gives the surface area of the plates, so we write:
##q_1 = \kappa \epsilon_0 E A \Rightarrow E = \frac{q_1}{\kappa \epsilon_0 A} = \frac{5.4 \times 10^{-5} C}{(8) (8.85 \times 10^{-12} \frac{F}{m}) (0.011 m^2)} = 6.934 \times 10^{7} \frac{V}{m} = 6.9 \times 10^{7} \frac{V}{m}##
5. To find the energy density of ##C_1##, simply use:
##u = \frac{1}{2} \epsilon_0 E^2 = \frac{1}{2} (8.85 \times 10^{-12} \frac{F}{m}) (6.934 \times 10^{7} \frac{V}{m})^2 = 21275.557 \frac{J}{m^3} = 21000 \frac{J}{m^3}##
Do these look good?
It's just rounding. To the two sig figs you kept, the sum is consistent with 240 V.
You could also use ##V=Ed## since the electric field is uniform. It's a bit simpler, though your calculation is fine too.
You need to account for the dielectric medium here.
Likes 1 person
FAQ: Capacitors in series with dielectrics
What is a capacitor in series with a dielectric?
A capacitor in series with a dielectric is a circuit component that consists of two or more capacitors connected in a series with a dielectric material placed between the plates. The dielectric material is an insulating material that can store electrical energy by polarizing in an electric field.
How does a dielectric affect the capacitance in a series capacitor?
The presence of a dielectric material in a series capacitor increases its capacitance. This is because the dielectric material has a higher dielectric constant than air, which allows for more electric flux to be stored between the plates of the capacitor.
What is the formula for calculating the equivalent capacitance in a series capacitor with dielectrics?
The formula for calculating the equivalent capacitance in a series capacitor with dielectrics is Ceq = C1 + C2 + C3 + ..., where C1, C2, C3, etc. are the individual capacitances of each capacitor in the series. This formula assumes that the capacitors are connected in series and there is no overlap or interaction between the dielectric materials.
How does a dielectric affect the voltage in a series capacitor?
The presence of a dielectric material in a series capacitor decreases the voltage across each individual capacitor. This is because the dielectric material reduces the electric field strength between the plates, resulting in a lower voltage drop across each capacitor.
What are some common applications of series capacitors with dielectrics?
Series capacitors with dielectrics are commonly used in electronic circuits for energy storage, filtering, and signal processing. They are also used in power transmission systems for voltage regulation and power factor correction.
