Capacitors in touch screens, parallel or series?
In summary, mutual capacitive touchscreens have two types of capacitors - parallel and series - while resistive touchscreens have resistors in series.
Elvislaur
Hi, I'm trying to find out are the capacitors in mutual capacitance touchscreens are in series or in parallel. I'm very confused because they're asking me what would happen if they were in parralel or in series?
maybe in mutual capacitive touch screens they're in series and in self capacitande-in parallel as shown in http://electronics.howstuffworks.com/iphone2.htm pictures..
Do you mean the capacitance at each crosspoint between the Driving and Sensing lines? Why would those capacitances be in series?
Now I'm getting an idea why they're in parallel, but why they're asking me to discus what would be if they would be in series? Cuz every crosspoint actually is like a capacitor.
You used the terms "mutual capacitance" and "self capacitance" in your original post (OP) above. I hadn't seen those terms before, so I looked them up on wikipedia.org.
The mutual capacitance is the normal capacitance we think of between two conductors (like plates of a capacitor, or the capacitance at the crosspoints of the touchscreens). The "self" capacitance is the capacitance of a single conductor to all other objects around it. Like the capacitance of a person standing in a room.
I don't quite get yet the use of these terms in touchscreen applications yet (I guess I need to do more reading). My impression of the touchscreen sensing was just that putting your finger over the driving line helped to increase the capacitive coupling of the driven signal into the sense line.
Does your reading of the link and other wikipedia/other articles suggest some other mechanism?
I've been reading a lot about this unfortunately there is not much info about latest capacitive touchscreens, but as far as i understand this now that there are two tipes of capacitive touch screens: Self capacitive and mutual capacitive, first one recognises only one touch at the same time like mine Xperia x10 and scnd is multi-touch like all iPhones with parallel capacitors..
I guess they want me to mention about resistive touch screens which are with resistors in series, but its another story without capacitance!
FAQ: Capacitors in touch screens, parallel or series?
What are capacitors in touch screens used for?
Capacitors in touch screens are used to store and release electrical charges, which allow the screen to detect touch input and respond accordingly.
Are the capacitors in touch screens connected in parallel or series?
The capacitors in touch screens are typically connected in parallel, meaning they are connected side by side and have the same voltage across them.
How do capacitors in touch screens work?
Capacitors in touch screens work by storing electrical charges between two conductive layers separated by an insulating layer. When a user touches the screen, the electrical charge is disrupted, causing a change in voltage that is detected by the device.
Can capacitors in touch screens be replaced or repaired?
In most cases, capacitors in touch screens cannot be replaced or repaired. They are typically manufactured as part of the screen and cannot be easily removed or replaced without damaging the device.
Do capacitors in touch screens affect the display quality?
Capacitors in touch screens do not directly affect the display quality. However, if they are damaged or malfunctioning, it can result in touch input issues and affect the overall functionality of the device.
