Capillary rise in tube of insufficient length
In summary, capillary rise is the movement of a liquid up a narrow tube due to cohesive and adhesive forces. In tubes of insufficient length, these forces can overcome gravity and cause the liquid to rise above the reservoir level. The rate of capillary rise is affected by factors such as surface tension, tube diameter, and contact angle. This phenomenon is observed in nature and utilized in technologies. The height and rate of capillary rise can be measured and calculated using various methods.
SDewan
32
When there is Capillary rise in tube of insufficient length, why does not the liquid overflow?
Capillary action is attractive: it pulls water into a tube.
Is this attraction due to adhesive - cohesive forces?
Related to Capillary rise in tube of insufficient length
What is capillary rise?
Capillary rise is the process by which a liquid, such as water, moves up a narrow tube or capillary due to the cohesive forces between the liquid molecules and the adhesive forces between the liquid and the tube walls.
How does capillary rise occur in a tube of insufficient length?
In a tube of insufficient length, the cohesive forces between the liquid molecules are strong enough to overcome the force of gravity, causing the liquid to rise above the level of the liquid in the reservoir.
What factors affect capillary rise in a tube of insufficient length?
The rate of capillary rise in a tube of insufficient length is influenced by several factors, including the surface tension of the liquid, the diameter of the tube, and the contact angle between the liquid and the tube walls. Additionally, the density and viscosity of the liquid, as well as the gravitational force, can also impact the capillary rise.
What are some real-life applications of capillary rise in tubes of insufficient length?
Capillary rise in tubes of insufficient length is a commonly observed phenomenon in nature, such as in plant roots and the movement of groundwater. It is also utilized in various technologies, such as wicking in candles and the ink in fountain pens.
How is capillary rise in a tube of insufficient length measured and calculated?
The height of capillary rise in a tube of insufficient length can be measured using a ruler or a graduated cylinder. The rate of capillary rise can be calculated using the Hagen-Poiseuille equation, which takes into account the tube diameter, liquid viscosity, and surface tension.
  • Other Physics Topics
  • Classical Physics
  • Mechanics
