- 23,770
- 11,224
- TL;DR
- My car's battery is not fully charging and/or is discharging significantly while parked. I'm trying to diagnose it.
I drive a 2019 Kia Stinger (purchased in June, 2019) with 22,000 miles on it. It's been having weak battery issues for a while, and I've ignored it but I really shouldn't, so now I'm trying to diagnose it to see if I need a new battery, new alternator or if there is a deeper electrical system issue -- or if I just need to adjust my care.
It has a "silver based battery", which google tells me a calcium-silver lead acid battery. Just a slight twist on a normal lead acid. Nameplate says it is 80 A-hr. I usually drive around 18,000 miles per year, but during COVID it has been down to maybe 6,000 this past year, including stretches where I only drive it a couple of times a week, short distance/time. The car has an auto-stop feature on the engine (the engine stops when the car is stopped), which has activated only rarely in the past year, I would think due to the weak battery. I have occasionally but rarely gotten a battery discharge warning when starting, indicating something is draining the battery while it is off. The only things plugged in all the time that didn't come from the factory are a bluetooth OBD adapter and remote start system.
My theory is that the battery discharges when the car is not in use and then doesn't get charged fully when in use. This weekend though, I drove it 4+ hours/160+ miles in 3 days and the auto-stop feature never engaged. I'd think that should be plenty for a full charge. So when I got home I measured the voltage with a volt-meter, at 12.32V. I then charged it with a quality multi-stage charger at a rate of 20A. Today after taking it off the charger it is at 12.96V. I'll watch it a few days to see how fast it drops.
Not achieving a full charge after several hours of driving implies a potential issue with the alternator, or perhaps the battery isn't accepting a full charge for some reason. But I'm not sure how that could happen.
I'd like to try and measure the discharge rate. I'm thinking of jumpering-in a 1 Ohm resistor and disconnecting the battery so I can measure the draw through the resistor - does that sound reasonable/risky?
Other thoughts on what could be going on here? Thanks.
