Car crash stimulus calculations
In summary, the conversation is about a car crash where car A is resting at the traffic lights and car B is driving at 100km/hr. Car B saw car A at 45m and stepped on the brakes. The velocity of car B is 27.8m/s, the deceleration is -6.7 m/s^2, and the thinking distance is 41.7m. The weight of car B is 1385 kg and the weight of car A is unknown. The person is asking for help in calculating the momentum, force, coefficient of friction, and velocity. They have calculated the momentum of both cars and are unsure if they have made a mistake because the momentum before the collision is greater than the
omgplshelpme
there is a car crash where car A is resting at the traffic lights and car B is driving at 100km/hr and at 45m saw the car and stepped on the brakes.
the velocity of car B is 27.8m/s
the deceleration is -6.7 m s^-2
weight of car A is x
i have to calculate the momentum, force, coefficient force and velocity etc...
i really need help
ty
welcome to pf!
hi omgplshelpme! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
ok i have calculated the momentum of both cars and the momentum before the collision is greater then the momentum after the collision, have i done something wrong? momentum before is suppose to equal momentum after
ah I am so confused
hi omgplshelpme! :wink:
show us your full calculations :smile:
I can provide some guidance on how to approach these calculations. First, we need to define some variables and equations that will help us solve the problem. Let's start with the basic equation for momentum, which is mass times velocity (p = mv). In this case, car B has a mass of 1385 kg and a velocity of 27.8 m/s, so its momentum would be 38,473 kg*m/s.
Next, let's consider the forces at play in this car crash. The car B is decelerating, which means there is a force acting in the opposite direction of its motion. We can use Newton's second law, which states that force (F) equals mass (m) times acceleration (a) to calculate the force on car B. In this case, the deceleration is -6.7 m/s^2 and the mass is 1385 kg, so the force would be -9294.5 N. This negative value indicates that the force is acting in the opposite direction of the car's motion.
To calculate the coefficient of friction, we need to consider the normal force (N) and the force of friction (Ff). The normal force is equal to the weight of the car (mg), so for car B it would be (1385 kg)(9.8 m/s^2) = 13,573 N. The force of friction can be calculated using the equation Ff = μN, where μ is the coefficient of friction. Rearranging this equation, we get μ = Ff/N. Therefore, the coefficient of friction for car B would be -9294.5 N / 13,573 N = -0.684.
Finally, we can calculate the velocity of car A using the conservation of momentum principle, which states that the total momentum before and after a collision must be equal. Since car A is stationary, its initial momentum is zero. Therefore, the final momentum of the two cars must also be zero. We can set up an equation using the masses and velocities of the two cars to solve for the velocity of car A. This would be (1385 kg)(27.8 m/s) + (x kg)(0 m/s) = 0. Solving for x, we get x = -38,473 kg*m/s / 0 m/s = 0 kg. This means that car A has no mass, which is
Related to Car crash stimulus calculations
1. What is a car crash stimulus calculation?
A car crash stimulus calculation is a scientific method used to determine the forces and impact of a car crash. It involves analyzing factors such as speed, mass, and direction of the vehicles involved to calculate the forces and energy involved in the collision.
2. How are car crash stimulus calculations used?
Car crash stimulus calculations are used by scientists, engineers, and accident reconstructionists to understand the dynamics of a car crash and determine the cause and severity of the collision. They can also be used to design safer cars and roads, and to improve safety regulations.
3. What factors are taken into account in a car crash stimulus calculation?
Factors such as the speed and direction of the vehicles, the mass and weight of the vehicles, and the type of collision (e.g. head-on, rear-end, etc.) are all taken into account in a car crash stimulus calculation. Environmental factors such as road conditions and weather may also be considered.
4. What tools or methods are used to calculate car crash stimuli?
Various tools and methods can be used to calculate car crash stimuli, including computer simulations, mathematical equations, and physical crash tests. These methods may use data from vehicle sensors, crash test dummies, and other sources to accurately calculate the forces and impact of a car crash.
5. How accurate are car crash stimulus calculations?
Car crash stimulus calculations can be very accurate when done by trained professionals using reliable data. However, there are many variables that can affect the accuracy of the calculation, such as human error, vehicle condition, and environmental factors. It is important to use multiple methods and data sources to ensure the most accurate results.
  • Classical Physics
