Car passing a truck — calculating the relative motions
In summary: The truck is ahead of the car by 60m.In summary, the conversation is about a physics problem involving a car and a truck. The question asks for a sketch and equations are discussed. Two quick graphs are provided but deemed insufficient. The car is said to accelerate for 2.8 seconds and travel 70.4 meters before reaching the speed limit of 25m/s. The average speed during the constant acceleration is calculated to be 22.5m/s. The distance covered is found to be 62.55 meters. The relative position of the car and truck at the end of the acceleration is discussed and it is determined that the truck is ahead of
  • #36
rssvn said:
Sorry for taking so long to answer, i understand now, (25m/s)t=37.5m+(18m/s)t -> 25t-18t=37.5m -> 7t=37.5m -> 5.36. Thank you @PeroK and @haruspex for bearing with me, i do appreciate it :)
Perhaps it's worth just summarising this.
There was a quick way to solve the problem, which is to take the difference in speeds of the car and the truck and the distance between them. In this case, the distance separating them was ##37.5m## and the car was traveling ##7m/s## faster than the truck. The time at which the car catches the truck is simply: $$t = \frac{37.5m}{7 m/s} = 5.36s$$
The other approach is to draw a graph of position against time of both vehicles. The point of intersection on the graph is the time at which the car catches the truck. This is related to the equations of motion as: $$x_{car} = (25m/s) t$$ and $$x_{truck} = 37.5m + (18m/s)t$$ represent straight lines on the graph and the point of intersection is the point where $$(25m/s) t = 37.5m + (18m/s)t$$ In any case, the important thing is to understand how these equations and graphs relate to the real motion and position of the vehicles.
  • #37
Don't we need to know the length of the truck ? Since 50m behind truck means 50m behind rear of truck. Still have further displacement (if not negligible) of truck length. See other "Car passing Truck" thread below.
  • #38
Not necessarily. If you are 50m behind in a race, that would be measured from front of vehicle to front of vehicle.
Likes neilparker62
  • #39
Relative velocity problem. Car traveling with initial velocity of 2m/s 50m behind "stationary" truck. Accelerates at 1.8 m/s/s till reaching 7m/s and maintains this until level with the truck. Area under graph up to t1 is 12.5m and 37.5m between t1 and t2. Simply add 18t for the actual displacement of car at t1 and t2 respectively.
Relative Velocity vs Time graph:
https://www.desmos.com/calculator/rgbooatiss
Relative Displacement vs Time graph:
https://www.desmos.com/calculator/ophyml0qrd
  • #40
True but I think there is a problem with the ambiguity. Initially you think something is not quite right but you can't exactly place it!
