Car Wing Design for Downforce: Efficiency Explored
In summary: The spoiler pictured can generate downforce but it may not produce the desired results if it is not mounted at a negative angle of attack.
personage
Hi everyone,
Just out of curiosity,
Will this car wing design be effective in generating downforce?
I've done some research and read that downforce is essentially the opposite of lift, so a design of an upside down airplane wing would be effective in producing a downforce - yet this car wing looks like a right-side up airplane wing. Maybe I'm just seeing this wrong though :biggrin:
So the design should be kind of like this one.. Or would this one not work either?
Thanks for your time!
Hard to come up with any kind of informed speculation without more information, like a cross section of the wing. Best bet may be to order one from some place with a good return policy and mount it on load cells to measure what it does.
Speed is much more important that fine points of wing design. You didn't say at what speed you need the down force.
As MrSpeedybob says, it's impossible to say without doing some testing. All else being the same, if an airfoil produces lift then inverting it will produce downforce - but all else is never the same, or no airplane would be able to fly upside down and many can. On a car, a wing can produce lift or downforce, but it also changes the flow of air over other parts of the car, causing them to generate more or less lift/downforce. In any case, the angle of attack (which is usually adjustable) is at least as important as the shape of the airfoil.
Well-heeled racing teams use wind tunnels and very sophisticated computer simulations. Less well-heeled teams spend a lot of time on the track and the skidpad making adjustments and seeing what works. But the sad truth is that the downforce generated by most aftermarket bolt-on aerodynamic devices acts mostly upon the purchaser's bank account.
Likes billy_joule
Based solely on that first picture, I would say yes, that wing could produce downforce, but it looks like it would incur quite a bit of drag doing so.
I suspect they are both designed to produce downforce. The cross section of the first one just isn't so obvious to see due to the end plates.
One thing to remember is that they rarely operate in free air. The air flow striking the wing is likely to be disturbed by the airflow over the car so the optimum angle of attack might look odd or perhaps not what you expect. The wing might need to have a twist in it if the airflow over the middle of the wing is at a different angle to the tips due to the shape of your car. In the early days wings were mounted very high up so they operated in clean air.
On a track/race car they are typically used to increase grip making cornering faster but at the expense of increased drag which reduces the top speed. It's a trade off. On ordinary roads you shouldn't be driving anywhere near the limit of adhesion so they are really just a bit silly and may increase fuel consumption.
More..
http://jalopnik.com/5659723/spoiler-alert-a-history-of-downforce
Likes billy_joule
There was a study done on this at UCSC, the angle is one of the most important factors check it out
http://www.bvmotorsports.com/spoilers.html
personage said:
I've done some research and read that downforce is essentially the opposite of lift...
True in vernacular usage but the term lift has a technical definition in aeronautical engineering (aerodynamic force perpendicular to the relative wind) that differs from the colloquial meaning (force pointing up).
The answer is simply and absolutely yes, the spoiler pictured can generate downforce but if and only if it is mounted so it meets the air at a negative angle of attack. Notice that the rear edge of this spoiler is tilted up to give the departing airflow an upward tilt; according to Newton's 3rd law of motion, the act of boosting the air upwards will result in downward force on the spoiler.
However, as CWATTERS correctly pointed out above, this spoiler would not be operating in undisturbed air (especially were it mounted on the rear deck of a notchback sedan) so mere eyeball engineering isn't sufficient to insure that the effective angle of attack at the desired speeds is indeed going to be negative. While the profile of the spoiler might have some effect upon how efficient it is in terms of (negative) lift generated vs. drag created, (known as the L/D ratio) the angle of attack is the only thing that determines if and which direction force will be exerted.
You guys realize this was a necropost, right?
Correction its http://bvmotorsports.com/home/learn/aerodynamics/spoilers-wings/
FAQ: Car Wing Design for Downforce: Efficiency Explored
1. What is downforce and why is it important in car wing design?
Downforce is the downward force applied on a car as it moves through the air. It is important in car wing design because it helps to increase the grip or traction of the car, allowing it to maintain stability and control at high speeds.
2. How does the shape and angle of a car wing affect downforce?
The shape and angle of a car wing can greatly impact the amount of downforce it generates. A curved or angled wing creates a pressure difference between the top and bottom surface, resulting in a downward force. The angle of the wing also affects the amount of air that flows over and under it, which can impact the amount of downforce generated.
3. Is there a trade-off between downforce and aerodynamic efficiency?
Yes, there is a trade-off between downforce and aerodynamic efficiency. While a larger wing can generate more downforce, it also creates more drag, which can slow down the car. This is why car wing design involves finding the right balance between downforce and aerodynamic efficiency to achieve optimal performance.
4. How do car manufacturers test and optimize their car wing designs for downforce?
Car manufacturers use wind tunnels and computer simulations to test and optimize their car wing designs for downforce. These methods allow them to analyze the airflow and pressure distribution around the wing and make adjustments to improve its performance.
5. Can car wing design for downforce also improve fuel efficiency?
Yes, car wing design for downforce can also improve fuel efficiency. A well-designed wing can reduce drag and improve the overall aerodynamics of the car, resulting in better fuel efficiency. This is why many modern cars have adjustable wings that can be optimized for different driving conditions.
