Carbon dioxide from an antacid tablet
In summary, the conversation discusses the results obtained from a lab experiment involving calcium carbonate and antacid tablets. The % concentrations of CaCO3 obtained from trial #1 and #2 were consistent, but the concentration from trial #3 was significantly higher. The use of a wet flask was suggested as a possible explanation for this result. The equations and calculations involved in the lab experiment were also mentioned. It was then explained that a wet flask would not release more CO2 and could actually result in a lower concentration of CaCO3. The concept of positive and negative error was also brought up in relation to the amount of CaCO3 present in the experiment.
Hyperfluxe
35
Let’s say the % concentrations of CaCO3 (table 5) you obtain from trial #1 and #2 are consistent, while the concentration obtained from trial #3 is significantly higher. Demonstrate, how and where, a wet flask could be involved to explain such a result. Explain in great details.
The equations under Calculations
https://docs.google.com/open?id=0By9VwoUlJRdCMzgxYjM1YzQtODA3MS00YmM5LWJiNjYtYmRlNDUwNDNjYTI3
Alright, so we did a lab with calcium carbonate and antacid today, reacting each with HCl and measuring the pressure/temperature before the reaction and then after the reaction. From this we can find the volume, amount, mass, etc. I have no idea as to how to approach this question, it seems as it wouldn't depend on whether the flask is wet or not - because a wet flask with release more CO2 but how does that contribute to the final concentration of calcium carbonate in an antacid tablet? Any hints would be appreciated.
Wet flask will not release MORE CO2. CO2 will start evolving before you start to collect it, so you will not collect everything.
Imagine you collected all of the gas and it was 44g of CO2 - how much CaCO3 was present?
Now imagine gas started to evolve too early and instead of 44g you collected only 1g. Use the same stoichiometry to calculate how much CaCO3 was present. Is it a positive, or negative error?
There would be a LOWER concentration of CaCO3 then! So the answer to the question would be NO, because if anything it would be a lower a concentration? Of course I have to back that up with reasoning + stoich. To answer your question, there would be 1g of CaCO3. What do you mean by postive/negative error?
Related to Carbon dioxide from an antacid tablet
1. How does carbon dioxide from an antacid tablet help with indigestion?
Carbon dioxide from an antacid tablet reacts with stomach acid to produce bubbles, which helps to neutralize excess acid and relieve symptoms of indigestion.
2. Can carbon dioxide from an antacid tablet cause any side effects?
In rare cases, carbon dioxide from antacid tablets can cause bloating, gas, or belching. However, these side effects are usually mild and temporary.
3. How long does it take for the carbon dioxide from an antacid tablet to start working?
The carbon dioxide from an antacid tablet will typically start working within 5-10 minutes after ingestion. However, the exact time may vary depending on individual factors and the severity of symptoms.
4. Is there a maximum amount of antacid tablets that can be taken in one day?
It is important to follow the recommended dosage on the packaging or as advised by a healthcare professional. Taking too many antacid tablets in one day can lead to potential side effects and may indicate a more serious underlying condition.
5. Can carbon dioxide from an antacid tablet interact with other medications?
Antacid tablets containing carbon dioxide may potentially interact with certain medications, such as antibiotics or heart medications. It is important to consult with a doctor or pharmacist before taking antacids if you are currently taking any other medications.
  • Biology and Medical
10K
