Carbon dioxide in liquid and gaseous phases with liquid water
In summary, the solubility of CO2 in water increases with the fugacity of the vapor, as predicted by Henry's law. However, when CO2 is in liquid form, the liquid CO2-liquid water interface is harder to achieve than the gaseous CO2-liquid water interface.
Zuzana Sediva
What are the differences between carbon dioxide solubility (miscibility, reaction) in liquid water when in gaseous (<38 bar) and liquid (>38 bar) phase? The temperature in my experiments is usually between 0 and 5°C. The stirring speed is around 500 rpm.
Is the solubility given apart from pressure and temperature by the co2-water interface?
Is there more phase - interface for the reaction between water and CO2 in the gaseous phase? According to Henry's law for real gases (including a Poynting correction), the solubility should rise with the fugacity of the vapor. How is it however, when the carbon dioxide is liquid? More CO2 should dissolve at higher pressures (CO2 in liquid phase), however the liquid CO2 - liquid water interface should be harder to achieve than the gaseous CO2-liquid water interface. Thank you very much.
Doesn’t the Poyntong correction apply only to the fugacity of the liquid? Are you considering non-ideality of the vapor phase mixture?
@ Chestermiller
Yes, the Poynting correction is at the Henry's constant for CO2 in the water solvent:
x_CO2=f_CO2/(H*exp^(V_co2 in water*(p-p_w))/(RT)), where H is the Henry constant for CO2 in water;
My question is more, how does CO2 and water interact when CO2 is gaseous and when liquid? Is there actually more dissolved at lower pressures because gas is more accessible to water than liquid CO2 or the other way around? The law above is clear until CO2 is gaseous. When CO2 is liquid, what happens?
Zuzana Sediva said:
@ Chestermiller
The non-ideal phase equilibrium behavior of mixtures at high pressures and with aqueous ionic solutions is too extensive to be covered in detail here. I refer you to Introduction to Chemical Engineering Thermodynamics by McCabe and Smith for a complete treatment.
Related to Carbon dioxide in liquid and gaseous phases with liquid water
1. What is the role of carbon dioxide in liquid and gaseous phases with liquid water?
Carbon dioxide plays a crucial role in regulating the Earth's temperature by trapping heat in the atmosphere. It also plays a role in the carbon cycle, as it is absorbed by plants during photosynthesis and released back into the atmosphere through respiration and decomposition.
2. How does carbon dioxide exist in liquid and gaseous phases with liquid water?
In its gaseous phase, carbon dioxide is a colorless and odorless gas that makes up a small percentage of Earth's atmosphere. In liquid form, it can be found in carbonated beverages or stored under high pressure for industrial purposes. When dissolved in liquid water, it forms carbonic acid, which affects the pH balance of the water.
3. What are the effects of carbon dioxide in liquid and gaseous phases with liquid water on the environment?
The increasing levels of carbon dioxide in the atmosphere are contributing to global warming and climate change. In liquid form, it can also contribute to ocean acidification, which can harm marine life and disrupt the ocean's delicate balance of nutrients and minerals.
4. How is carbon dioxide used in various industries?
Carbon dioxide is used in a variety of industries, including food and beverage production, where it is used to carbonate drinks and preserve food. It is also used in oil and gas extraction, as well as in fire extinguishers and refrigeration systems.
5. What are some potential solutions for reducing carbon dioxide in liquid and gaseous phases with liquid water?
Some potential solutions for reducing carbon dioxide emissions include transitioning to renewable energy sources, implementing carbon capture and storage technology, and promoting reforestation and other carbon sequestration methods. Additionally, reducing our overall carbon footprint and promoting sustainable practices can also help mitigate the effects of carbon dioxide on the environment.
  • Mechanics
13K
  • General Discussion
9K
  • Chemistry
  • Mechanics
  • Chemistry
