Cardinality and existence of injections
In summary, to prove that if \textrm{card}(X)\leq\textrm{card}(Y) is not true, then \textrm{card}(X)\geq\textrm{card}(Y) must be true, we can use Zorn's lemma to find an injection from either X to Y or Y to X. This is equivalent to the axiom of choice and the trichotomy law for cardinals. There are also other proofs available, such as showing that the cardinality of every set is an "aleph" and that the alephs are totally ordered.
jostpuur
2,116
How do you prove that if [itex]\textrm{card}(X)\leq\textrm{card}(Y)[/itex] is not true, then [itex]\textrm{card}(X)\geq\textrm{card}(Y)[/itex] must be true?
In other words, if we know that no injection [itex]X\to Y[/itex] exists, how do we prove that an injection [itex]Y\to X[/itex] must exist?
This is not the same thing as what Cantor-Bernstein-Schroeder theorem answers, right?
Mathematics news on Phys.org
Hi jostpuur! :smile:
The answer I could give you depends on what you already know about set theory. The thing you mention is called "the trichotomy law for cardinals" and it is equivalent to something called "the axiom of choice".
There are several ways to prove the trichotomy law. The easiest way seems by using Zorn's lemma:
Let X and Y be arbitrary sets. We want an injection [itex]X\rightarrow Y[/itex] or [itex]Y\rightarrow X[/itex]. We must find a partial ordering such that the injections are the maximal objects, on this partial ordering, we would apply Zorn's lemma.
Let
[tex]F=\{f~\vert~f~\text{is an injection with}~Dom(f)\subseteq X,~Im(f)\subseteq Y\}[/tex]
And order F by
[tex]f\leq q~\Leftrightarrow~Dom(f)\subseteq Dom(g)~\text{and}~\forall x\in Dom(f):f(x)=g(x)[/tex]
Now we apply Zorn's lemma on F with this ordering and we find an injection f such that either [itex]Dom(f)=X[/itex] or [itex]Im(f)=Y[/itex]. In the first case, we have an injection [itex]X\rightarrow Y[/itex], in the second case, the inverse of f defines an injection [itex]Y\rightarrow X[/itex].
[/INDENT
Other proofs are also possible. For example, one can also show that the cardinality of every set is an "aleph", and since the alephs are totally ordered, so are the cardinalities of sets.​
Related to Cardinality and existence of injections
1. What is cardinality?
Cardinality refers to the measure of the number of elements in a set. It is a mathematical concept that is used to compare and describe the sizes of sets.
2. What is the difference between cardinality and existence of injections?
While cardinality refers to the number of elements in a set, the existence of injections relates to the possibility of mapping one set onto another without any element being mapped to more than one element. Injections are a type of function that preserves the size and distinctness of a set.
3. How do you determine the cardinality of a set?
The cardinality of a set can be determined by counting the number of elements in the set or by using the concept of one-to-one correspondence, where each element in the set is paired with a unique element in another set. In general, the cardinality of a set is denoted by the symbol |A|, where A is the set.
4. Can a set have the same cardinality as its power set?
No, a set cannot have the same cardinality as its power set. The power set of a set is defined as the set of all subsets of that set, including the empty set and the set itself. The cardinality of the power set is always greater than the cardinality of the original set.
5. How do injections relate to the existence of a bijection?
Injections are a type of function that is one-to-one, meaning each element in the domain is mapped to a unique element in the range. If a function is both an injection and a surjection (where every element in the range is mapped to by at least one element in the domain), then it is a bijection. This means that there exists a one-to-one correspondence between the two sets, and they have the same cardinality.
