Cardinality of Set A: 1 or $\le$1?
In summary, the cardinality of a set refers to the number of distinct elements in the set. It cannot be less than 1 and must always be a whole number. The symbol $\le$ represents "less than or equal to" and a set with a cardinality of $\le$1 either has one element or no elements at all. The cardinality of a set is determined by counting the number of distinct elements in the set using methods such as listing or mathematical techniques.
ozkan12
149
Suppose that set A have unique element...Can we say that cardinality(A)=1 or $cardinality(A)\le1$ ? Which one is true ?
Both are true.
Hi ozkan12,
For a finite set Cardinality is the number of elements in the set. If $A$ contains only one element its cardinality is $1$. Saying $\mbox{Cardinality}(A)=1$ is more precise than saying $\mbox{Cardinality}(A)\leq 1$ since the former tells $A$ has exactly one element, whereas the latter tells $A$ has one or no elements.
First of all, Thank you for your attention...İn your opinion, Which is true ? How both of them is true ?
You are welcome. This is similar to writing $x=1$. And then saying $x\leq 1$. The $\leq$ sign represents "less than OR equal to". Therefore if $x=1$, it implies that $x\leq 1$ also. In words, $x$ is equal to one and therefore it is also true that $x$ is less than or equal to one.
That is, we can say that x=1 is more general than $x\le1$
$x=1$ gives more information as it tells us specifically that $x=1$ whereas $x\leq 1$ gives less information; $x$ can be one or it can be less than one.
FAQ: Cardinality of Set A: 1 or $\le$1?
What does it mean for the cardinality of a set to be 1?
The cardinality of a set refers to the number of distinct elements in the set. Therefore, if the cardinality is 1, it means that there is only one element in the set.
Can the cardinality of a set be less than 1?
No, the cardinality of a set cannot be less than 1. The cardinality of a set must always be a non-negative integer, as it represents the number of elements in the set.
What does it mean for the cardinality of a set to be $\le$1?
The symbol $\le$ represents "less than or equal to." Therefore, if the cardinality of a set is $\le$1, it means that the set either has one element or no elements at all.
Can a set have a fractional or decimal cardinality?
No, the cardinality of a set must always be a whole number. It is not possible for a set to have a fractional or decimal cardinality as it represents the count of distinct elements.
How is the cardinality of a set determined?
The cardinality of a set is determined by counting the number of distinct elements in the set. This can be done by listing out all the elements in the set and then counting them, or by using mathematical techniques such as set operations and logic.
