Carnot Refrigerator Homework: Coeff of Performance, Work & Heat
In summary, the question is asking for the coefficient of performance (COP) of a Carnot refrigerator operating between -30.0 ^ C and + 20.0 ^ C, which is the ratio of the heat removed from the cold reservoir to the work added to the system. The problem provides the heat extracted from the cold reservoir (300 J/s) but does not give the work added to the system. To solve this, you can use the fact that a Carnot refrigerator follows the equation Q1/Q2 = T1/T2, where Q1 is the heat removed from the cold reservoir and Q2 is the heat exhausted to the hot side. By using a block diagram, you can find the relation between Q1,
dragon162
A Carnot refrigerator operating between -30.0 ^ C and + 20.0 ^ C extracts heat from the cold reservoir at the rate 300 J/s. What are (a) the coefficient of performance of this refrigerator, (b) the rate at which work is done on the refrigerator and (c) the rate at which heat is exhausted to the hot side?
As you can tell I did not include the relevant equations due to the fact that I am very confused here. All I know is that for part A the coefficent of performance of a refrigerator is the ratio of the heat removed from the cold reservoir to the work added to the system. The problem tells me the heat extracted from the cold reservoir but I don't know how to get the work added tot he system. Any help would be appreciated.
Use the fact it's Carnot refrigerator (as opposed to a non-ideal refrigerator). You have enough given information to calculate the coefficient of performance for such a refrigerator.
Yeah, you know that e=Qout/Win. In the case of a carnot cycle Q1/Q2 = T1/T2. You can use a block diagram to get the Q1, Q2, and work relation.
The COP for a heat pump and a refrigerator are different. If Qout is the heat delivered to the hot register (the outside), you are using the COP for a heat pump. For a refrigerator,
COP = Qc/Win
where Qc is the heat removed from the cold reservoir (ie the inside of the fridge).
AM
I meant Qout as in what you get out of doing the cycle. We always care about the ratio of what you get out compared with what you put in (e = Out/In). What you get out here is Qc, and what you put in is work W.
Related to Carnot Refrigerator Homework: Coeff of Performance, Work & Heat
1. What is the coefficient of performance for a Carnot refrigerator?
The coefficient of performance (COP) for a Carnot refrigerator is equal to the ratio of the amount of heat removed from the cold reservoir to the amount of work done on the refrigerator. It can be expressed as COP = Qc / W, where Qc is the heat removed from the cold reservoir and W is the work done on the refrigerator. In an ideal Carnot refrigerator, the COP is equal to the ratio of the absolute temperatures of the hot and cold reservoirs, or COP = Th / (Th - Tc).
2. How does the work done by a Carnot refrigerator compare to the heat removed from the cold reservoir?
In a Carnot refrigerator, the work done on the refrigerator is equal to the heat removed from the cold reservoir. This is because a Carnot refrigerator operates on a reversible cycle, meaning that all of the work done on the refrigerator is converted into heat that is removed from the cold reservoir. Therefore, the work and heat are equal in magnitude but have opposite signs.
3. What is the relationship between the coefficient of performance and the absolute temperatures of the hot and cold reservoirs?
The coefficient of performance for a Carnot refrigerator is directly proportional to the absolute temperature of the hot reservoir and inversely proportional to the absolute temperature of the cold reservoir. This means that as the hot reservoir temperature increases, the COP also increases, while as the cold reservoir temperature decreases, the COP increases. However, the COP can never exceed the ratio of the absolute temperatures, as it is a measure of efficiency.
4. Can a Carnot refrigerator achieve a coefficient of performance greater than 1?
No, a Carnot refrigerator cannot achieve a coefficient of performance greater than 1. This is because a COP greater than 1 would imply that the refrigerator is able to remove more heat from the cold reservoir than the work done on it, which violates the second law of thermodynamics. The maximum COP for a Carnot refrigerator is equal to the ratio of the absolute temperatures of the hot and cold reservoirs.
5. How does the coefficient of performance of a Carnot refrigerator compare to that of a real refrigerator?
The coefficient of performance of a Carnot refrigerator is an idealized value that assumes a reversible cycle and no energy losses. In reality, real refrigerators operate on irreversible cycles and experience energy losses, leading to a lower COP. The COP of a real refrigerator is always less than the maximum COP of a Carnot refrigerator, but the closer the real refrigerator's operation is to a reversible cycle, the closer its COP will be to that of a Carnot refrigerator.
