Carrying Multiple Frequencies On A Single Copper Cable
In summary, superposing waves with the same frequency results in interference, while superposing waves with different frequencies doesn't.
mahela007
106
how can a single copper cable carry all the different frequencies and prevent them from interfering with each other and destroying data? (I posted this question in the physics forums because it has to do with waves and frequencies)
The different-frequency waves superpose and do not interfere with each other (or at least if they do interfere, it's in ways that can be controlled and limited). They can be separated from each other using tuners and filters, along with the information that they carry. This leads to the various schemes for modulating the information onto the waves, by varying the amplitude, frequency, and/or phase of the waves.
So.. superposing is different from interference?
Think of it like a sound recording of a rock band. The sound of the bass, guitar, drums, and vocals are all individual sound waves when they are originally performed live. When they are recorded onto a medium, they are added together into a single wave to be reproduced by speakers. Your brain is able to differentiate the different components of the band even though all the sound is a single wave coming from a single speaker.
If you add together (superpose) two or more waves with the same frequency, you get another single wave with that frequency, and you can't separate it back into its original waves. In that case we can call it "interference" of the original waves. If you add together two or more waves with different frequencies, you get a complex waveform that doesn't have a single frequency, and you can separate it back into its original waves. Mathematically, we describe the process using Fourier analysis. Physically we implement it with with electronic filters that pass certain frequencies and block others.
This may help you visualize it:
http://www.colorado.edu/physics/2000/applets/fourier.html
But don't be mislead by the word "destructive" in the title. It's somewhat of a misnomer, since the waves are not really being destroyed (unless both waves are of the same frequency).
There is another type of signal separation on a single pair of copper wires. The simplest example is simultaneous bi directional voice transmission on the standard telephone two-line pair. The two voice signal travel through each other at about 2/3 the speed of light without interfering. Directional couplers on the line can pick off either voice separately. Modems (modulator-demodulators) do this at MHz frequencies.
Due to a limit of saturation of electrons at any specific point in a wire, wouldn't this affect the actual peak limits from combined signals, resulting in some clipping of the combined signals?
Thanks guys!
FAQ: Carrying Multiple Frequencies On A Single Copper Cable
What is the advantage of carrying multiple frequencies on a single copper cable?
Carrying multiple frequencies on a single copper cable allows for more efficient use of the cable, as multiple signals can be transmitted simultaneously. This can increase bandwidth and improve overall network performance.
How does carrying multiple frequencies affect signal quality?
The quality of the signals carried on a single copper cable can be affected by interference between the different frequencies. However, with proper shielding and signal processing techniques, this interference can be minimized and the overall signal quality can be maintained.
Can different types of signals (e.g. voice, data, video) be carried on a single copper cable?
Yes, different types of signals can be carried on a single copper cable by using different frequency bands for each type of signal. This can allow for more efficient use of the cable and can help reduce the number of cables needed for a network.
What are the limitations of carrying multiple frequencies on a single copper cable?
The main limitation of carrying multiple frequencies on a single copper cable is the potential for signal interference, which can affect the overall quality of the signals being transmitted. Additionally, the bandwidth of the cable may also be limited, which can impact the number of frequencies that can be carried.
What are some applications for carrying multiple frequencies on a single copper cable?
Carrying multiple frequencies on a single copper cable is commonly used in telecommunications, such as in DSL and cable internet services. It can also be used in other industries, such as in medical devices and industrial automation, to transmit various types of data over a single cable.
17K
