Cart, Incline, Pulley, and a messed up Acceleration.
The discussion revolves around a physics problem involving a cart on an incline with a pulley, where the calculated acceleration is approximately 1, while the expected answer is 0.77. The correct approach involves using the angle of 26 degrees for calculations, specifically applying the formula Fgx = mass x gravity x sin(26). After recalculating, the force due to gravity on the incline is determined to be around 15.5 N. The final equation for acceleration is clarified as a = (m1gsin26 - m2g) / (m1 + m2), yielding an accurate acceleration of approximately 0.7728. Properly applying the trigonometric relationships and forces involved is crucial for obtaining the correct result.
Some_Thing
The question and my work can be seen in the image below:
http://img145.imageshack.us/img145/550/scan0001fgu.jpg
The problem is that I am getting around 1 for acceleration, while the answer is 0.77.
What am I doing wrong?
rock.freak667 said:
Upload the image here [URL]http://imageshack.us and paste the forum code so that we can see it and try to help you.
Oops, I was using a url from hotmail. It showed up fine for me, but I guess that was because I was logged in at the time.
Thanks.
The angle remains 26 and not 64. So Fgx = mass x gravity x sin theta where theta is 26 degrees.
Fgx = mass x gravity x sin 26
Fgx = 3.6 x 9.8 x sin 26
Fgx = 15.465
This rounds off to 15.5 N, which is what I got.
NOTE: cos 64 = sin 26
You have got another force in the rope m2a.
Your equation should look something like this:
m2g+m2a+m1a=m1gsin26
a=(m1gsin26-m2g)/(m1+m2)
a=0.7728
  • · Replies 37 ·
  • · Replies 22 ·
  • · Replies 22 ·
