Case changed when submitted
  • Thread starter Jonathan Scott
In summary, when a case changes when submitted, it means that there has been a modification to the capitalization of the text, which can happen automatically or manually. It is important to check settings or review any changes made to the text to determine the cause. The case can be changed back after submission, either by adjusting settings or manually. In most cases, the change in case will not affect the meaning of the text, but it is important to review for potential alterations. Paying attention to case changes is important as it can impact the readability and professionalism of the document. It is recommended to review and edit the text for proper capitalization before submission.
Jonathan Scott
1,152
When I entered the following reply in the "Where are you" thread, the letters N and W were in upper case, but in the post they came out in lower case, even after attempting to edit it to change it. Is there a reason for this?
50°58'32.15"N 1°24'00.78"W
FAQ: Case changed when submitted
What does it mean when the case changes when submitted?
When a case changes when submitted, it means that there has been a modification to the capitalization of the text. This can happen when the text is automatically formatted or when someone manually changes the case of the text.
Why did the case change when I submitted my text?
The case may have changed when you submitted your text due to automatic formatting settings in your word processing program. It could also be a result of manually changing the case of the text. Check your settings or review any changes you made to the text to determine the cause.
Can I change the case back after it has been submitted?
Yes, you can change the case back after it has been submitted. If the case change was due to automatic formatting, you can adjust the settings to prevent it from happening again. If it was manually changed, you can simply undo the changes or manually change the case back to its original form.
Will the case change affect the meaning of the text?
In most cases, the change in case will not affect the meaning of the text. However, there may be instances where the capitalization of a word or phrase can change its meaning. It is important to review the text carefully to ensure that the intended meaning is not altered.
Is it important to pay attention to case changes when submitting text?
Yes, it is important to pay attention to case changes when submitting text. While it may not always affect the meaning of the text, it can impact the readability and professionalism of the document. It is always best to review and edit the text for proper capitalization before submitting it.
