Casimir force experiments under environmental EM noises?
In summary: Overall, the success of Casimir force measurements relies heavily on careful control of the laboratory environment. In summary, conducting accurate Casimir force measurements requires careful control of the laboratory environment. This includes minimizing external electromagnetic fields, controlling temperature and humidity, reducing vibrations, and shielding against external electric and magnetic fields. Techniques such as Faraday cages, filters, and vibration isolation systems are commonly used to achieve this control. The success of these measurements depends on the precision of these techniques.
pchu
I've always been curious about how rigorous are the Casimir force measurements carried out, because a couple of years ago I read some news about people inventing perpetual motion machine which turned out to be draining power from environmental EM noises, say, radio station, wifi, 3G/4G that keep broadcasting 24/7 nowadays.
The first papers of experiments confirming Casimir force, e.g. Mohideen & Roy (1998) used a standard AFM, which, I suppose, does have requirements on EM environment and techniques to limit that influence. But for experiments using customized design, e.g. L. Tang et al. 2017 (Nature Photonics), I wonder whether there's general requirement on EM condition in every lab like this so that they need not mention it (in which case, how's the restriction?) OR environmental EM noises are totally irrelevant and will not alter the result (in which case, is there an estimation? how well is Casimir effect against EM noises?)
In either case, what are the techniques used to limit environmental EM noises in experiments? The environment of a lab conducting Casimir force measurements must be carefully controlled in order to ensure accurate results. Generally speaking, this includes minimizing external electromagnetic fields, controlling temperature and humidity, reducing vibrations, and shielding against external electric and magnetic fields. To minimize external electromagnetic fields, researchers typically use Faraday cages to shield against external electric and magnetic fields, and filters to reduce interference from radio frequencies. In addition, temperature and humidity must be closely monitored and controlled to ensure that the results remain consistent over time. Finally, vibration isolation systems are often used to reduce any mechanical vibrations that may affect the measurements.
Related to Casimir force experiments under environmental EM noises?
1. What is the Casimir force?
The Casimir force is a physical phenomenon that occurs between two uncharged, closely spaced parallel plates in a vacuum. It is caused by quantum fluctuations in the vacuum, which create a force that pushes the plates together.
2. How is the Casimir force measured in experiments?
In experiments, the Casimir force is typically measured using a torsion balance or an atomic force microscope. These instruments can detect extremely small forces between the plates, allowing for accurate measurements of the Casimir force.
3. What is meant by "environmental EM noises" in Casimir force experiments?
Environmental EM noises refer to electromagnetic (EM) fields that exist in the environment and can interfere with Casimir force measurements. These noises can come from a variety of sources, such as electronic devices, thermal radiation, or even cosmic rays.
4. How do environmental EM noises affect Casimir force experiments?
Environmental EM noises can interfere with Casimir force measurements by introducing additional forces that may mask or distort the true Casimir force. These noises can also cause fluctuations in the measured force, making it difficult to obtain accurate and reproducible results.
5. What measures can be taken to minimize the effects of environmental EM noises in Casimir force experiments?
To minimize the effects of environmental EM noises, researchers can use shielding materials to block out external EM fields, conduct experiments in a vacuum chamber, and carefully design and calibrate their instruments. Additionally, statistical analysis techniques can be used to filter out random fluctuations caused by environmental noises.
