Cast iron specific heat in function of the temp
In summary, jlefevre76 provided me with the relationship between cast iron specific heat and temperature in order to perform a disc brake thermal analysis. I will use this information to do my analysis.
serbring
271
Hi all,
I need the relationship between cast iron specific heat and temperature in order to perform a disc brake thermal analysis. Where could I get this data? I just need average values for a typical cast iron used for disc brakes.
Any suggestion is appreciated
Thanks
Scroll down to the part that says specific heat. Apparently, ductile iron is a type of cast iron. I've never liked the term cast iron very much, as it's a little confusing just what one means when they use the term. As I remember from materials science, cast iron has a high carbon content, higher than what steel generally contains.
Anyway, http://www.ductile.org/didata/Section3/3part2.htmseems to be referring to cast iron as a high carbon alloy.
Or copy and paste link if you desire: http://www.ductile.org/didata/Section3/3part2.htm
Note: since it gives a range, I would find the average of the range and assume that as the temperature. For instance, 20-200 C would assume 110 C. 20-300 C would assume 160 C.
Hi jlefevre76,
thanks for your reply, you provide me what I need.
cheers
FAQ: Cast iron specific heat in function of the temp
1. What is specific heat?
Specific heat is the amount of heat required to raise the temperature of a substance by one degree Celsius.
2. Why is specific heat important for cast iron?
Specific heat is important for cast iron because it affects the amount of heat needed to change its temperature, which can impact its physical and mechanical properties.
3. How does the specific heat of cast iron change with temperature?
The specific heat of cast iron typically decreases with increasing temperature, meaning that as the temperature of cast iron increases, it requires less heat to change its temperature.
4. What factors can affect the specific heat of cast iron?
The specific heat of cast iron can be affected by factors such as its chemical composition, microstructure, and impurities.
5. How is specific heat of cast iron measured?
The specific heat of cast iron can be measured using instruments such as a calorimeter or a differential scanning calorimeter, which can measure the heat absorbed or released by a substance during a temperature change.
