Casual Dynamical Triangulation
In summary, CDT assumes that space is divided into simplexes, which are basically tetrahedrons, and each tetrahedron is subdivided into smaller tetrahedrons. This creates a 2-dimensional space near the Planck scale.
Nano-Passion
1,291
I came across casual dynamical trangulation with is closely related to loop quantum gravity and I found the theory very attractive. http://en.wikipedia.org/wiki/Causal_dynamical_triangulation
There was one thing that caught my attention that I didn't really understand.
Wikipedia said:
At large scales, it re-creates the familiar 4-dimensional spacetime, but it shows spacetime to be 2-d near the Planck scale, and reveals a fractal structure on slices of constant time.
What do they mean by fractal structures? When I hear fractal I think about fractal geometry, does that have anything to do with it?
Consider a stone, it has a certain stone structure.
Now raise the scale, and you're looking at a rock.
Strangely enough it has the same structure on a larger scale.
Then rock formation, and ultimately mountain.
I turns out that nature is build of fractals, that is, things look the same regardless of scale.
The term is coined from "fraction" indicating a broken dimension.
That is, the surface area of a rock is greater than the corresponding sphere.
But if you look in more detail, you'll find that the surface area is greater still, up to infinity.
So the surface of a rock has a fractal dimension between 2 and 3.
That was exactly my assumption. Fractal geometry is awesome haha.
So them how many dimensions does CDT assume? I read that they treat space as discrete slices that can rotate at an angle.
I'm sorry if I make anything sound silly, words can often lead people astray. I wonder what is the mathematical language behind this type of space?
Reading the article I get the impression that it's not a fractal geometry.
Space-time is divided into simplexes, which are basically tetrahedrons, and each tetrahedron is subdivided into smaller tetrahedrons.
In other words, is just a partitioning of space.
"Fractal" sounds very cool of course, but I don't think that's what this is. :(
I think the explanation is not so simple.
We have to find a suitable definition of "dimension". The idea is to use the so-called spectral dimension which can be extracted from a diffusion process.
You can find some remarks regarding spectral dimension and CDT here:
http://arxiv.org/abs/hep-th/0505113
Spectral Dimension of the Universe
Authors: J. Ambjorn (NBI Copenhagen and U. Utrecht), J. Jurkiewicz (U. Krakow), R. Loll (U. Utrecht)
(Submitted on 12 May 2005 (v1), last revised 6 Jun 2005 (this version, v2))
Abstract: We measure the spectral dimension of universes emerging from nonperturbative quantum gravity, defined through state sums of causal triangulated geometries. While four-dimensional on large scales, the quantum universe appears two-dimensional at short distances. We conclude that quantum gravity may be "self-renormalizing" at the Planck scale, by virtue of a mechanism of dynamical dimensional reduction.
A diffusion equation can be used to study the diffusion of a gas in D-dimensional space with a point-like source. This is a kind of delta-source which we need for the Greens function of the diffusion equation. From this Greens function we can calculate the return-probability of a gas particle after a certain time, i.e. we start the diffusion process at t=0, x=0 and check whether a certain gas particle returns to x=0 at t=T. Of course this return probability p depends on T and on the dimension D of space in which the diffusion process takes place, i.e. we have a function p(T,D). Analytically the diffusion equation contains the laplacian of D-dimensional space. From the analytical solution for the Greens function and the return probability p(T,D) one can determine D.
On graphs this does no longer work b/c there is no differential equation describing the diffusion process. First one defines a graph as the dual w.r.t. the triangulation simplices. Then we study a random walk on the graph which corresponds to the diffusion process. At each step t, t+1, t+2, ... the particle moves along one edge of the graph. Again we study the return probability at time t=T to the starting point. Then we apply the return probability formula derived for the continuum diffusion process to calculate D from p(T,D) extracted from the random walk.
Up to now this can be checked in a very simple way: use a D-dim. lattice, implement a random walk, count the steps for the return to the origin and calculate p(T,D). And of course one can generalize this algorithm for arbitrary but fixed (!) graphs. In this way one can define a dimension D for an arbitary graph G, i.e. D(G). This is the so-called spectral dimension.
What the CDT people do is to create samples for their triangulation, i.e. for their graphs (using something like Metropolis, importance sampling etc.), to extract the spectral dimension D(G) for each graph G and to calculate the ensemble average <D> for graphs contained in a certain ensemble. In that way one finds different CDT regimes for which there are different values for this averaged <D>.
It is this <D> derived via the scaling dimension for a "diffusion process on a graph representing spacetime" which shows somehow "fractal behaviour".
This dimension <D> must not be confused with the Haussdorf dimension typically used for fractals!
FAQ: Casual Dynamical Triangulation
What is Casual Dynamical Triangulation?
Casual Dynamical Triangulation (CDT) is a computational approach used to model the behavior of spacetime at the quantum level. It is based on the concept of triangulating spacetime into discrete building blocks, called simplices, and then evolving them in a probabilistic manner. This approach is used to study the properties of quantum gravity.
How does CDT differ from other approaches to quantum gravity?
CDT differs from other approaches to quantum gravity, such as string theory or loop quantum gravity, in that it does not rely on a pre-existing classical spacetime. Instead, it constructs spacetime from the ground up, using the discrete simplices as building blocks. This makes it a non-perturbative approach, meaning it does not rely on small perturbations around a classical solution.
What are the main challenges in studying CDT?
One of the main challenges in studying CDT is the difficulty of performing simulations on large enough spacetimes to accurately capture the behavior of quantum gravity. This requires significant computational resources and sophisticated algorithms. Additionally, the interpretation of the results can be challenging due to the non-perturbative nature of the approach.
What are some potential applications of CDT?
CDT has the potential to provide insights into the behavior of spacetime at the Planck scale, where the effects of quantum gravity are expected to be significant. It can also help us understand the early universe and the nature of black holes. CDT may also have applications in other fields, such as condensed matter physics and information theory.
What are some current research topics in the field of CDT?
Current research in CDT includes exploring the phase structure of quantum spacetime and the nature of the transition between different phases. Other topics of interest include the emergence of classical spacetime from the discrete building blocks, the role of topology in quantum gravity, and the behavior of matter fields in a CDT universe.
