MHB Category Theory - Initial and Final Objects
Math Amateur
MHB
I am reading Paolo Aluffi's book, Algebra: Chapter 0.
I am currently focused on Chapter I, Section 5: Universal Properties.
I need some help Example 5.3 and Exercise 5.2 in this section.
QUESTION 1Example 5.3 reads as follows:View attachment 4484
Can someone clearly explain why $$\emptyset$$ is initial ...
We need every set $$A$$ in the category Set to have exactly one morphism (set function):
$$\emptyset \rightarrow A$$
and Aluffi seems to be saying that the 'empty graph' ( an "empty or nothing function" ? ) is the unique function from $$\emptyset$$ to $$A$$ ... is that right ...?
It seems a highly contrived function (morphism) ... indeed, what is the empty graph exactly ... and how do we rigorously justify the assertion that it is actually a function ...
Can someone please explain clearly just what Aluffi is saying here ... ?
QUESTION 2
Exercise 5.2 in Chapter I, Section 5 reads as follows:View attachment 4485Can someone show me how to construct a rigorous and formal proof for this exercise ... ?Help will be much appreciated ...
PeterPeter
Hi Peter,
It could be useful to remember that a function between two given sets $A, B$ is a subset of $A \times B$ (with some other properties, of course)
Peter,
I've given this explanation to you before (that $\emptyset$ is initial in Set), but it's been a while and it doesn't hurt to reiterate. ;) Let $A$ be a set. A morphism $\emptyset \to A$ is a relation from $\emptyset$ to $A$, i.e., a subset $R$ of $\emptyset \times A$ such that for every $x \in \emptyset$, there is a unique $a \in A$ such that $(x,a) \in R$. Now since $\emptyset \times A = \emptyset$, $R = \emptyset$. So there is only one morphism $\emptyset \to A$.
Now let $X$ be a set such that for every set $A$, there is exactly one morphism $X \to A$. Then in particular, there is only one moprhism $X \to \emptyset$. Every element of $X$ maps to only one element of $\emptyset$; this cannot happen unless $X = \emptyset$. There, $\emptyset$ is the unique initial object in Set.
Euge said:
Peter,
Thanks for for that post, Euge ... It is most helpful and clear ...
My apologies for forgetting the advice and help that you gave some time earlier ...
Peter
- - - Updated - - -
Fallen Angel said:
Hi Peter,
indeed ... a helpful point that is essentially the clue to the situation ... Thanks Fallen Angel ..
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
