Catenary - find rope length Maple must be used
In summary, the conversation discusses the use of separation between poles by utilities companies and the computation of the required length of the power line between poles. It suggests using Newton method or any "Find root" instruction to solve a nonlinear equation and deriving a formula from the computation of the integral of the arc length. The conversation also mentions the use of Maple to solve the problem and asks for advice on solving it without Maple.
bur7ama1989
Utilities companies usually use a separation between poles about 340 feet. These poles are 34 feet tall and due to restrictions due to maximum height of trucks using interstates and state routes, the minimum clearance is 20 feet (and also considering the increase of sag of the cable due to expansion in the summer time). Compute the required length of the power line between poles.
Note 1: From Eq. (1) for y(170)=34 and y(0)=20, it can be solved (numerically) the parameter a from a single nonlinear equation. Use Newton method or any "Find root" instruction to solve this nonlinear equation. The starting guess value a0 for these techniques can be obtained graphically (show this graph). Once the value of parameter a has been found (4 decimal places accuracy), use it in Eq. (4) to find the length of the cable.
Note 2: Derive Eq. (4) from the computation of the integral of the arc length of y(x) in Eq. (1). Compute symbolically this integral to verify the result of Eq. (4).
(1) y(x) = (a)(cosh(x/a)) + C
(2) a = H/w
(3) cosh(x) = ((e^x) + (e^-x))/2
(4) L = (2a)(sinh(M/a))
I attempted using Maple's "solve" command to solve for L, a, and C. Needless to say it did not work.
The answer yielded without evalf() was as follows for a:
a = 28*exp(RootOf(14*_Z*exp(_Z)-85*(exp(_Z))^2+170*exp(_Z)-85))/(exp(RootOf(14*_Z*exp(_Z)-85*(exp(_Z))^2+170*exp(_Z)-85))-1)^2
With the evalf() i yielded:
a = Float(infinity), L = Float(undefined), C = Float(-infinity)
I also substituted as suggested using y(170)=34 and y(0)=20. I solved for "C" in y(170) and yielded:
C= -a*cosh(170/a)+34
I substituted this into y(0) and yielded:
a-a*cosh(170/a)+14 = 0
Now that i have an equation equal to zero with a single variable I can now use Newton's method. So I assigned the new equation to f(a):
f(a) = a-a*cosh(170/a)+14
I next assigned g(a) to the derivative of f(a):
g(a) = 1-cosh((170)/(a))+(170 sinh((170)/(a)))/(a)
I assigned h(a) to Newton's Method. Now the issue is that no matter which value I choose it doesn't seem to work. I graphed the function f(x) and g(x) and it does not seem to intersect with the x-axis whatsoever so I am not quiet sure if I derived the correct equation by my substitution. I would really appreciate some expert advice of which the members on this site have an abundance. Thank for your time. I realize this is a long question, but I don't think the question is simple...in my opinion.
I have solved the problem, but it makes me feel good to see that a bunch of people viewed the thread and no replies. I assume it was a brain buster for the people who viewed it. Fact remains I couldn't find an exact value, but i achieved the desired decimal place accuracy.
Hi,
I have the exact same problem and information with which to work out the length of a catenary. I don't have maple at my disposal!
Can you please advise on how I might solve this problem??
Your help would be much appreciated!
buy it, check your college library or computer lab, or download it using torrents
Related to Catenary - find rope length Maple must be used
What is a catenary?
A catenary is the curve that results from the hanging of a flexible and uniform rope or chain under its own weight.
How do you find the length of a rope using Maple?
To find the length of a catenary rope using Maple, you can use the "catenary" function with the known parameters of the rope, such as the weight per unit length and the distance between the hanging points.
Why is Maple used to find the rope length in a catenary?
Maple is a mathematical software program that has built-in functions for solving equations and performing complex calculations. It is specifically designed for scientific and mathematical applications, making it an ideal tool for finding the length of a catenary rope.
Are there any limitations to using Maple to find the rope length in a catenary?
Yes, there can be limitations depending on the complexity of the catenary curve and the accuracy required in the calculation. Maple may not be able to provide an exact solution in some cases, and manual calculations may be needed for more precise results.
What are some real-life applications of finding the rope length in a catenary?
Finding the length of a catenary rope can be useful in engineering and architecture, such as in the design of suspension bridges and arches. It can also be used in physics and mathematics for understanding the properties of curves and forces.
  • Classical Physics
