Cathode Ray Tube in a uniform magnetic field
In summary, the trajectory of the electrons in a CRT placed in a uniform magnetic field is a helix, and they will touch the axis again at a time of 2πm/Bq and a displacement of 2π(mv/Bq) (cosθ) from the origin.
mad_scientist
A CRT is placed in a uniform magnetic field B, with the axis of the tube parallel to the lines of force. If electrons emerging from the gun with a velocity v make an angle θ as they pass through the origin O so that their trajectory is a helix, show that a) they will touch the axis again at the time t= 2πm/Bq
b) that the coordinate of the point of touching is x= 2π(mv/Bq) (cosθ)
t= 2πm/Bq
x= 2π(mv/Bq) (cosθ)
a) The time taken for an electron to travel from the origin O to a point on the axis is given by 2πm/Bq.b) The displacement of the electron from O to the point on the axis is given by x= 2π(mv/Bq) (cosθ).
I would approach this problem by first understanding the basic principles involved. A cathode ray tube is a device that uses a beam of electrons to create an image on a fluorescent screen. The electrons are accelerated by an electric field and then deflected by a magnetic field, allowing them to be focused and directed to specific points on the screen. In this case, the tube is placed in a uniform magnetic field, which means that the strength and direction of the field are constant throughout the region.
Based on this setup, we can use the equations provided to determine the time and coordinates at which the electrons will touch the axis again. The equation t=2πm/Bq represents the time it takes for an electron with charge q and mass m to complete one full revolution in a magnetic field B. This is known as the cyclotron frequency. Therefore, when the electron touches the axis again, it will have completed one full revolution.
Similarly, the equation x=2π(mv/Bq)(cosθ) represents the distance along the x-axis at which the electron will touch the axis again. This equation takes into account the velocity of the electron (v), the strength of the magnetic field (B), and the angle (θ) at which the electron passes through the origin O.
To show that these equations are correct, we can use the known values for the mass and charge of an electron, as well as the given velocity and angle, to calculate the expected time and coordinate of touching. By plugging in these values, we should arrive at the same results as the equations provided.
In conclusion, the equations t=2πm/Bq and x=2π(mv/Bq)(cosθ) accurately represent the time and coordinate at which an electron in a CRT will touch the axis again in a uniform magnetic field. This understanding can be applied to further study and improve the design and functionality of cathode ray tubes and other devices that use magnetic fields to manipulate electron beams.
Related to Cathode Ray Tube in a uniform magnetic field
1. How does a Cathode Ray Tube work?
A Cathode Ray Tube (CRT) is a vacuum tube that uses an electron beam to create an image on a fluorescent screen. The electron beam is produced by heating a cathode and accelerating the electrons towards an anode. The beam then passes through a series of electrodes and deflecting plates, creating the image on the screen.
2. What is a uniform magnetic field?
A uniform magnetic field is a magnetic field that has the same strength and direction at every point in a given region. This means that the force experienced by a charged particle moving through the field will be constant and in the same direction throughout its path.
3. How does a uniform magnetic field affect the electron beam in a CRT?
When a CRT is placed in a uniform magnetic field, the beam of electrons generated by the cathode will experience a force perpendicular to both the direction of the beam and the direction of the magnetic field. This force will cause the beam to deflect and create a curved path on the screen.
4. What is the purpose of a uniform magnetic field in a CRT?
The uniform magnetic field in a CRT is used to control the path of the electron beam and create the desired image on the screen. By adjusting the strength and direction of the magnetic field, the beam can be directed to different areas of the screen, allowing for the creation of different images.
5. Are there any drawbacks to using a CRT in a uniform magnetic field?
One potential drawback of using a CRT in a uniform magnetic field is that it requires a significant amount of energy to maintain the vacuum and generate the electron beam. Additionally, CRTs are bulky and can be easily damaged, making them less practical for modern devices that require more compact and durable displays.
  • General Engineering
