Cation/cation repulsion in salt water solution
In summary, adding salt to a water/surfactant solution can trigger the change in shape of spherical micelles to cylindrical micelles of the surfactant DTAB. This is because the repulsion between cationic heads can be reduced by the addition of salt, which reduces the coulombic forces between molecules. The higher polarity of water, due to its higher dielectric constant, increases the coulombic forces, while the ions in salt decrease the dielectric constant, leading to a decrease in coulombic forces and a reduction in net positive charge on the micelle surface. This, in turn, triggers the change in shape.
sghan
Spherical Micelles of the surfactant DTAB, which has a cationic head, will turn into cylindrical micelles if the repulsion between the cationic heads can be reduced. I have read that adding salt (perhaps NaCl or NaBr) to this water/surfactant solution will reduce repulsion between the cations, thus triggering the change in shape. Can someone explain how adding salt would reduce coulombic forces between molecules? Salt is supposed to reduce the dielectric constant of water. Coulombic forces are inversely proportional to the dielectric constant, meaning adding salt should INCREASE repulsion. Or is the more relevant mechanism here simply that salt anions are attracted to the positive micelle surface, reducing net positive charge?
Thanks!
Back to basics here! Do ions feel more or less coulombic attraction when dissolved in a polar solvent (compared to a less polar medium)? Does higher polarity of solvent increase the forces or decrease them? In other words, does the polarity of the solvent affect its dielectric constant (permittivity) and how? I understand that ions of salt will decrease the dielectric constant of water, however the role of water's polarity in determining its dielectric constant is unclear!
Exactly.
I merged your two threads as they look like the same topic.
FAQ: Cation/cation repulsion in salt water solution
What is cation/cation repulsion in salt water solution?
Cation/cation repulsion in salt water solution refers to the phenomenon where positively charged ions, known as cations, repel each other in a solution containing salt. This is due to the like charges on the cations, which causes them to push away from each other.
Why does cation/cation repulsion occur in salt water solution?
Cation/cation repulsion occurs in salt water solution because the salt, or sodium chloride, dissociates into its ionic components in water. This produces positively charged sodium ions (Na+) and negatively charged chloride ions (Cl-). The positively charged cations repel each other, leading to cation/cation repulsion.
How does cation/cation repulsion affect the behavior of salt water?
Cation/cation repulsion affects the behavior of salt water by causing the ions to spread out and become evenly distributed throughout the solution. This helps to maintain the stability of the solution and prevents the ions from clumping together.
Can cation/cation repulsion be observed in everyday life?
Yes, cation/cation repulsion can be observed in everyday life. For example, when salt is added to a glass of water, the cations and anions will repel each other and spread out evenly throughout the solution. This is also seen in the formation of ocean water, where the positively charged sodium and magnesium ions repel each other and create a stable solution.
How does cation/cation repulsion impact other substances dissolved in salt water?
Cation/cation repulsion can impact other substances dissolved in salt water by preventing them from interacting with each other. For example, if a negatively charged anion is added to a salt water solution, the positively charged cations will repel it, making it difficult for the anion to bond with another substance. This can affect the solubility and chemical reactions of different substances in salt water.
