Cauchy Riemann conditions/equation
In summary, the Cauchy-Riemann's conditions state that in the proof, there is an equality between differentials of the same function (f(z)) by x (real part) and by iy (imaginary part). This is because in the complex plane, z is the only variable and x and y are just the real and imaginary parts of z. The limit as h approaches 0 must be the same, regardless of whether it is approached from above or below. This is due to the fact that the complex plane is two dimensional, while the real line is one dimensional, resulting in more restrictions on the complex derivative.
MartinV05
23
In the proof of the the Cauchy-Riemann's conditions we have and equality between differentials of the same function (f(z)) by x(real part) and by iy(imaginary part?).
Why do we "say" that both differentials should be equal when it's normally possible to have different differentials according to the variable used?
Picture related (the equality in the last part):
There is only one variable here- z. And the derivative is with respect to that variable. "x" and "y" are not independent variables, they are the real and imaginary parts of the single variable z.
Here they are just taking the limit in "[itex]\lim_{h\to 0}(f(z+h)- f(z))/h[/itex]" as h approaches 0 in different ways. If the limit itself exists, then the limit as h approaches 0 in any way must be the same. You can do the same in differentiation of functions of a real variable- the limits as h goes to 0 "from above" and "from below" must be the same. It is the fact that the complex plane is two dimensional while the real line is only one dimensional the gives more restrictions on the complex derivative.
So no matter how z changes (whether real or imaginary) the limit should be the same, because they both actually complete the other "higher" variable. I know the that approaching from 0- and 0+ should be the same with limits in real variables, but never would have thought of this in that way. Think you!
Related to Cauchy Riemann conditions/equation
What are the Cauchy-Riemann conditions?
The Cauchy-Riemann conditions are a set of necessary and sufficient conditions for a function of a complex variable to be differentiable at a given point. They state that the partial derivatives of the function with respect to the real and imaginary parts of the complex variable must exist and must satisfy a specific relationship at that point.
What is the Cauchy-Riemann equation?
The Cauchy-Riemann equation is the mathematical expression of the Cauchy-Riemann conditions. It states that if a function of a complex variable is differentiable at a point, then the partial derivatives of the function with respect to the real and imaginary parts of the complex variable must satisfy a specific relationship at that point.
Why are the Cauchy-Riemann conditions important?
The Cauchy-Riemann conditions are important because they provide a way to determine if a function of a complex variable is differentiable at a given point. This is crucial in complex analysis and has many applications in physics, engineering, and other fields.
What is the geometric interpretation of the Cauchy-Riemann conditions?
The Cauchy-Riemann conditions can be interpreted geometrically as a system of two equations that describe the relationship between the real and imaginary parts of a complex function at a given point. They can also be thought of as the conditions for a function to preserve its shape and orientation under a conformal mapping.
What is the relationship between the Cauchy-Riemann conditions and the analyticity of a function?
The Cauchy-Riemann conditions are a necessary and sufficient condition for a function of a complex variable to be analytic. This means that if a function satisfies the Cauchy-Riemann conditions at a point, then it is differentiable at that point and therefore analytic. Conversely, if a function is analytic at a point, then it automatically satisfies the Cauchy-Riemann conditions at that point.
  • Calculus
