Cauchy-Schwarz for two spacelike vectors
In summary, the Cauchy-Schwarz inequality in Euclidean geometry states that the absolute value of the dot product of two vectors is less than or equal to the product of their magnitudes. However, in Minkowskian signature, this inequality is reversed for timelike vectors and depends on whether the two vectors span the light cone for spacelike vectors. A proof for this can be derived by considering the inner product of a vector with itself and using the discriminant of a quadratic polynomial. This concept is further discussed in a homework problem in a book on special relativity.
bcrowell
Staff Emeritus
Insights Author
431
You can use the idea of the "usual" proof for the Euclidean case. If ##v## and ##w## are space-like then for any real number ##t## consider the vector ##x=v+tw## and its inner product with itself. You have ##(x,x)=(v+tw,v+tw)=|v|^2+2(v,w)t+|w|^2t^2##. The inequality holds if and only if the discriminant of the quadratic polynomial is negative, if and only if the polynomial has only positive values. So if the inequality hold if and only if the span of the two vectors consists of space-like vectors.
Likes bcrowell
Thanks, martinbn! I'll have to work that out and make sure I understand it.
I have a discussion of Cauchy-Schwarz and triangle inequalities now in section 1.5 of my SR book, http://www.lightandmatter.com/sr/ . The case we discussed here is relegated to a homework problem, where I suggest the idea of martinbn's argument (with credit to martinbn) and ask the reader to carry it out.
Related to Cauchy-Schwarz for two spacelike vectors
1. What is the Cauchy-Schwarz inequality for two spacelike vectors?
The Cauchy-Schwarz inequality states that for two vectors a and b, the absolute value of their dot product is less than or equal to the product of their magnitudes. This can be expressed mathematically as |a · b| ≤ |a||b|.
2. How is the Cauchy-Schwarz inequality used in physics?
In physics, the Cauchy-Schwarz inequality is used to prove the existence of energy-momentum tensors in relativity, as well as in the study of quantum mechanics and statistical mechanics. It is also used in the derivation of the Lorentz transformations, which describe the relationship between space and time in special relativity.
3. What is the significance of two vectors being "spacelike" in the Cauchy-Schwarz inequality?
In mathematics, vectors can be classified as timelike, spacelike, or lightlike depending on their relationship to the speed of light. Spacelike vectors are those that are perpendicular to the time axis, meaning that they do not have a time component. In the Cauchy-Schwarz inequality, using two spacelike vectors ensures that the inequality holds true in all reference frames.
4. Can the Cauchy-Schwarz inequality be extended to more than two vectors?
Yes, the Cauchy-Schwarz inequality can be extended to any number of vectors. This is known as the generalized Cauchy-Schwarz inequality and states that the absolute value of the dot product of any two vectors is less than or equal to the product of their magnitudes multiplied by the cosine of the angle between them.
5. How does the Cauchy-Schwarz inequality relate to the concept of orthogonality?
The Cauchy-Schwarz inequality is closely related to the concept of orthogonality, which describes the relationship between two vectors that are perpendicular to each other. In fact, the Cauchy-Schwarz inequality is sometimes referred to as the orthogonality principle, as it states that the dot product of two orthogonal vectors is equal to zero.
  • Linear and Abstract Algebra
