B Causation: substance or event?
  • B
  • Thread starter Thread starter sayetsu
The discussion centers on the distinction between "substance causation" and "event causation" in the context of a car hitting a pedestrian. It questions whether the car itself or the transfer of kinetic energy is responsible for the pedestrian's death. A forensic pathologist is suggested as a more appropriate authority for determining the cause of death, emphasizing the role of energy transfer and bodily stress in fatal injuries. The conversation also touches on the philosophical implications of causation, though it notes that discussing philosophy may violate forum rules. Ultimately, the thread concludes with a reminder that the topic is complex and may not be suitable for further exploration in this context.
sayetsu
TL;DR Summary
If a car runs into a pedestrian, does the car kill them, or the kinetic energy?
A philosopher makes a distinction between "substance causation" and "event causation." If a speeding car (substance) hits a pedestrian, does the collision with the car (touching it while it's moving fast) kill the person, or does the transfer of kinetic energy or something - what, exactly, causes them to die, and how?
sayetsu said:
TL;DR Summary: If a car runs into a pedestrian, does the car kill them, or the kinetic energy?
Assuming the person does die - which is by no means certain - you'd be better off asking a forensic pathologist than a philosopher to ascertain the cause of death.
  • Haha
Likes Dale, russ_watters, Ibix and 1 other person
I would say that the transfer of energy and momentum to some parts of the pedestrian's body and not others leads to stresses inside the body which are too great for the elasticity of some part(s) of the body and they break. That breakage may be fatal.
I don't think trying to fit this into what sounds like a knock-off of Aristotle's four causes is a good idea, not least because discussing philosophy is against forum rules.
Likes russ_watters and vanhees71
As a poor layman of philosophy, I should appreciate it if you could provide simple definition or show weblinks to get idea of event causation and substance causation to understand your discussion better. I found another word agent causation https://en.wikipedia.org/wiki/Agent_causation. Is it also involved in ?
Philosophy is out of bounds here. Thread closed.
  • Love
Likes Bystander, anorlunda, Ibix and 2 others
Thread ''splain this hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
