muralidharan
- 1
how does pressure on a submerged body in water experience an upward thrust ,when the cause of pressure is gravity, which can only be downwards
The premise of this question is wrong. Pressure is not caused by gravity. For example, the international space station is pressurized even though it is in microgravity. Pressure is a contact force between a fluid and a surface, it is not caused by gravity, and it acts in a direction perpendicular to the surface (which may be upwards).muralidharan said:how does pressure on a submerged body in water experience an upward thrust ,when the cause of pressure is gravity, which can only be downwards
!Dale said:Pressure is not caused by gravity.
Consider a pressurized container of gas in 0 g. There is pressure and there is no gravity. Therefore, pressure is not caused by gravity.Shreyas Samudra said:you are wrong
You would do well not to make rash assertions that someone else is wrong. In particular when you are wrong yourself. As Dale has already stated, gravity is neither required for or directly causing pressure. That a fluid in a gravitational field experiences a pressure gradient, leading to a buoyant force, is a different thing.Shreyas Samudra said:!
you are wrong
pressure is force / area, that force may gravitational or something else, whatever
Orodruin said:a fluid in a gravitational field experiences a pressure gradient, leading to a buoyant force, is a different thing.
For the buoyant force, yes. This is just where Archimedes' principle comes from.Shreyas Samudra said:That is the thing in this case !
Gravitational force is a force on a mass, not an area force. That this force leads to internal forces causing a pressure gradient is something else entirely. The pressure force itself is a contact force, it certainly is not a gravitational force.Shreyas Samudra said:pressure is force / area, that force may gravitational or something else, whatever
?Orodruin said:Pressure can be quite relevant even if the net buoyant force is zero
Shreyas Samudra said:?
if we have pressure varying throughout the liquid column , buoyant force is non zero
What you quoted from Dale and claimed was wrong was not a statement about the buoyant force, it was a statement about pressure. Pressure can be quite relevant even if the net buoyant force is zero - just go diving without equilibrating the pressure in your ears and you will see - or my favourite when flying, closing an empty PET bottle at maximum altitude and observing the effects as the flight descends
but when i click on the reply option i can see this
Also, you are wrong in your statement that pressure is a result from gravity:
Orodruin said:Poor choice of words, intended net buoyancy. This is the buoyant force minus the gravitational force.
Edit: Actually, not bad choice of words. I was talking about a situation where there is no (significant) gravitational field leading to a pressure gradient - as was Dale. What you will feel in your ears when you dive or go flying is not the result of a pressure gradient on your body - it is a very local phenomenon based on the pressure difference between the outside and inside of your ears.
SorryOrodruin said:Please use quotes properly. Otherwise it is impossible to know what you are saying and what you are quoting. I edited the post shortly after posting it. You must have loaded it in the meantime.
Of course he has not, he has not been logged in since before post #2 was made.Shreyas Samudra said:murlidharn,
have you got this all ??
Exactly, neither did Dale's quote that you claim is wrong. It never mentioned buoyancy. Please read the posts that you are going to claim are wrong.Shreyas Samudra said:this has nothing to do with buoyancy,
buoyancy is resultant of all the 'local' forces (exerted by fluid on the body inside the fluid)
For A to cause B there are several conditions. Most importantly, A must be a necessary and sufficient condition for B. As I have shown above, gravity is neither necessary nor sufficient for pressure, therefore gravity is not the cause of pressure.Shreyas Samudra said:That is the thing in this case !
and
There is concrete thinking and there is formal thinking. All your points are quite correct (unarguable, in fact) but are they helping a questioner who wants a concrete view of the phenomenon? (It's a 'B' question)Dale said:For A to cause B there are several conditions. Most importantly, A must be a necessary and sufficient condition for B. As I have shown above, gravity is neither necessary nor sufficient for pressure, therefore gravity is not the cause of pressure.
In this case there is gravity and there is pressure and buoyancy is related to both, but gravity is still not the cause of pressure. This is important because of the logic of the OP, which goes: gravity causes pressure, gravity points down, therefore pressure must point down. The recognition that gravity does not cause pressure allows the OP to then learn what does cause it, and then correct his chain of logic.
Again, gravity does not cause pressure. It is neither necessary nor sufficient. Please do not post further misinformation to the effect that it is the cause.
Not you too. No, gravity does not cause pressure! See above. If I take a scuba tank and fill it up, then the pressure is much higher than it was previously, but the gravity is not any different.sophiecentaur said:Gravity causes the pressure under water (On Earth, of course).
The OP has presented a specific chain of logic which is based on a flawed premise. I don't know how you expect him to learn if the flawed premise is not addressed. If you (falsely) agree and say "gravity causes pressure" then his reasoning that "therefore it must point down" is much harder to address.sophiecentaur said:There is concrete thinking and there is formal thinking. All your points are quite correct (unarguable, in fact) but are they helping a questioner who wants a concrete view of the phenomenon? (It's a 'B' question)
The same argument could have been made about the function of a see-saw. Gravity acts downwards so the lighter person should move down. Reductio ad absurdum can be a good argument.Dale said:gravity causes pressure, gravity points down, therefore pressure must point down.
Hmm. The pressure at the depth of water in this particular context, is only there because of the local gravitational field. ("full stop"Dale said:Gravity is not the cause of pressure. Full stop.
That actually was exactly the other argument that I was considering.sophiecentaur said:The same argument could have been made about the function of a see-saw. Gravity acts downwards so the lighter person should move down. Reductio ad absurdum can be a good argument.
No. Consider an object submerged in a hydrostatic fluid inside a pressure vessel. The pressure can be substantially increased independently of the gravitational field. Only the pressure gradient is there because of the gravitational field.sophiecentaur said:Hmm. The pressure at the depth of water in this particular context, is only there because of the local gravitational field. ("full stop")
I do agree with this as long as the specific answer does not incorrectly teach a wrong general principle. Saying that pressure is caused by gravity is flat out wrong, both in general and in specific. It was stated by the OP (and now by two others including yourself), so clearly it is a common misconception.sophiecentaur said:Specific answer to specific questions are quite acceptable in many circumstances.
I don't think so. I don't see any indication that the OP is not familiar with the formula for hydrostatic pressure. He just didn't understand how it could point any direction other than downwards given the premise that it is caused by gravity. Citing the formula doesn't address the specific reasoning of the OP.sophiecentaur said:if you google with the term 'hydrostatic pressure' you will find
P = ρhg in pretty much every hit. That's all the OP needed.
(My emphasis)sophiecentaur said:is only there because of the local gravitational field.
To expand on that, consider the resulting stream of fluid if a hole is poked in the side.russ_watters said:It may be useful to consider what happens when you depress a piston into a cylinder containing a fluid. Clearly, the piston applies a force in one direction. It may be easy to see how you get a reaction in the opposite direction, but what about the pressure applied to the sides of the piston...?
You could well be right but, in the context of Buoyancy of a floating object (see the title) than the only relevant thing that produces the pressure is the weight of fluid on top and that is not caused by anything other than g (pretty well uniform at any relevant height). After a description around Archimedes' principle, 'other causes' of pressure could have been introduced - after getting some response from the OP.Chestermiller said:The OP seems to think that a gravitational field is the only thing that can cause pressure in a fluid.
The OP was asking about the physical mechanism responsible for buoyancy. But, to start with, he implied that pressure is caused only by gravity. Dale felt it was necessary to correct the frequent misconception of PF posters that gravity is the only thing that can give rise to pressure, before proceeding to a discussion of the actual physical mechanism. I also felt compelled to set the record straight on this.sophiecentaur said:You could well be right but, in the context of Buoyancy of a floating object (see the title) than the only relevant thing that produces the pressure is the weight of fluid on top and that is not caused by anything other than g (pretty well uniform at any relevant height). After a description around Archimedes' principle, 'other causes' of pressure could have been introduced - after getting some response from the OP.
Pascal's Principle was a good idea to introduce and it links (with a nice authoritative name) the downwards force due to gravity with a force in any other direction.
What is the point of introducing other reasons for the existence of pressure in order to explain flotation, which happens (in virtually any situation that I can think of) in bodies of fluid under the influence of gravity. This is a B QUESTION so why not limit replies appropriately? I am not arguing with any of the Physics that's been quoted here but I think all that stuff may have driven the OP away. Did we want that?
I agree with nearly all of that. But, in the context, the only 'cause' is gravity. We're talking elementary physics where abstract concepts like Pressure are certainly not appreciated fully by students. If the OP had only worded his question "the cause of THE pressure is gravity" then how could anyone have objected? Overkill responses can be very counter productive - our guy seems to have just gone away as a result.Chestermiller said:The OP was asking about the physical mechanism responsible for buoyancy. But, to start with, he implied that pressure is caused only by gravity. Dale felt it was necessary to correct the frequent misconception of PF posters that gravity is the only thing that can give rise to pressure, before proceeding to a discussion of the actual physical mechanism. I also felt compelled to set the record straight on this.
With regard tot he actual physical mechanism, Shreyas Samudra indicated by the buoyant force could be determined simply be integrating the pressure (as a scalar) over the surface area of the body. I felt compelled to correct this, and add that the integration had to be done vectorially, taking into account the normalcy of the pressure force at each location on the surface.
I disagree. We owe it to our members to correct misconceptions, particularly misconceptions that, experience shows, are shared by many others. With regard to the OP, if he has left, that is unfortunate. But he is certainly not the only member who reads this thread and who can benefit from our correcting this misconception (rather than allowing it to stand and be reinforced).sophiecentaur said:I agree with nearly all of that. But, in the context, the only 'cause' is gravity. We're talking elementary physics where abstract concepts like Pressure are certainly not appreciated fully by students. If the OP had only worded his question "the cause of THE pressure is gravity" then how could anyone have objected? Overkill responses can be very counter productive - our guy seems to have just gone away as a result.
If you felt that it was overkill then you could have simply formulated your own simpler but correct response instead of going out of your way (multiple times) to argue against a correct response (indeed one that you yourself describe as "unarguable").sophiecentaur said:Overkill responses can be very counter productive
I thought that was exactly what I did in post #18. Perhaps I should have started the post with my explanation and ended with the remark about the 'high level' disagreements. I never argued against the more advanced stuff about pressure (I agree with it all, of course). I guess a less grumpy response on my part would have avoided this. My apologies.Dale said:If you felt that it was overkill then you could have simply formulated your own simpler but correct response instead of going out of your way (multiple times) to argue against a correct response (indeed one that you yourself describe as "unarguable").
Buoyant force is the upward force exerted by a fluid on an object immersed in it. It is caused by the difference in pressure between the top and bottom of the object, with higher pressure at the bottom pushing the object upward.
Buoyant force is directly related to pressure, as it is caused by a difference in pressure between the top and bottom of an object. The greater the difference in pressure, the greater the buoyant force.
Yes, gravity plays a significant role in buoyant force. Gravity pulls the object downward, while buoyant force pushes it upward. The net force acting on the object is the difference between these two forces, which determines whether the object will sink or float.
The shape of an object affects the amount of fluid displaced, which in turn affects the buoyant force. Objects with a larger volume will displace more fluid and experience a greater buoyant force. Additionally, objects with a larger surface area will experience a greater difference in pressure and therefore a greater buoyant force.
Buoyant force and upward thrust are essentially the same thing. Upward thrust is the force that pushes an object upward when it is submerged in a fluid, while buoyant force is the name given to this upward force. They are both caused by the difference in pressure between the top and bottom of the object.
