A Cause of upward motion of a nutating top
  • A
  • Thread starter Thread starter Kashmir
    Cause Motion
The upward motion of a nutating top is explained by the balance of gyroscopic torque and gravitational torque. When the precession rate exceeds the necessary rate to maintain balance, the top experiences upward nutation until equilibrium is restored. This overshoot occurs due to inertia, leading to oscillations around the angle where the torques balance. The initial conditions significantly influence whether nutation occurs, as specific angles can lead to a stable state without nutation. Thus, nutation is fundamentally an oscillation resulting from deviations from this equilibrium angle.
Kashmir
The locus of the rotational axis of a symmetrical rotating top with a fixed base is shown. This shows a nutation bounded by two circles.
What is the intuitive explanation as to why the top axis turns upwards at the lower circle and moves up? ( I understand the circular precession caused by gravity and would be grateful for an explanation only for the nutation).
Thank you :)
It depends on initial conditions. For any given angle wrt vertical, there is a matching precession rate that will involve no nutation, because the gyroscopic torque balances the gravity exactly. If the initial condition is of this sort, there will be no nutation.
On the other hand, if the precession rate is, say, higher than required to match the gravity, then the top will nutate upwards for a moment until the balance is achieved. However, it will overshoot the balance point due to inertia, and so an oscillation will be set up. So nutation is an oscillation around the angle at which gyro torque balances torque due to gravity -- an oscillation due to initial perturbation from the "neutral" angle.
Likes berkeman and vanhees71
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
