Causes Virtual Particles or Vacuum Energy or Other?
In summary, the double slit experiment with one slit operating at a 180 degree phase shift can still produce a "virtual" wave front, and the photons that are canceled out contribute to virtual particles and vacuum energy, potentially affecting the force on a Casimir plate sensor and playing a role in gravity.
rchase
33
I understand the basics of the double slit experiment.
I'm trying to imagine what would happen if one slit could operate at a 180 degree phase shift, or nearly that. The obvious answer is not much except between the slits, and even less if the distance between the slits is near the wave length.
(Note if one slit operated at 180 phase shift and spaced a n-wave lengths from the first slit, it would be targeted to completely destroy the other wave, but produce a 'virtual' wave front of nothing.)
My question is: Do the photons still exist despite not much happening (elecromagnetically)?
A step further: Do photons which are canceled by another slit gone, or do they contribute to the virtual particles or vacuum energy or something like that?
Far out question: Could we control the force on a casimir plate sensor?
I know there are some interfered photons. My question is about the things we can't see, are there more missing photons all around us which can't be recovered? Can we setup an emitter which emits an entirely canceled wave. If so, is there a sea of photons which are essentially summing to zero. And if so, how does this affect vacuum energies and virtual interactions, or gravity for that matter...
The answer to your questions is yes. Photons that are canceled out by the 180 degree phase shift still exist, but they do not interact electromagnetically with other photons. The effect of their existence is that they contribute to the virtual particles and vacuum energy. If two waves of equal amplitude and opposite phase are produced, then their effect will be to produce what is known as a "destructive interference" pattern in which the electromagnetic fields cancel each other out. This has an effect on the force on a Casimir plate sensor, as it decreases the overall force due to the canceling of waves. In terms of the sea of photons, yes, there can be photons that sum to zero and these are referred to as "virtual photons". These virtual photons play an important role in quantum field theory, contributing to vacuum energy and virtual interactions. As for their effect on gravity, this is still an open question and is an area of active research.
FAQ: Causes Virtual Particles or Vacuum Energy or Other?
What are virtual particles?
Virtual particles are particles that are predicted by quantum field theory to exist in a vacuum. They are not directly observable, but their effects can be detected through certain experiments.
How are virtual particles related to vacuum energy?
Virtual particles are thought to arise from the fluctuations of vacuum energy, which is the energy associated with empty space. These fluctuations create temporary imbalances in energy, leading to the creation of virtual particles.
What is the significance of virtual particles in physics?
Virtual particles play a crucial role in many fundamental processes in physics, such as the decay of particles and the interactions between particles. They also contribute to the vacuum energy of the universe and may have implications for the behavior of the universe on a larger scale.
Can virtual particles be observed directly?
No, virtual particles cannot be observed directly because they exist for only a very short amount of time and do not leave any measurable traces. However, their effects can be indirectly observed through various experiments and calculations.
Are virtual particles real?
Virtual particles are a mathematical concept used in quantum field theory to describe the behavior of particles and their interactions. While they are not directly observable, their effects and predictions have been confirmed through experiments and are considered to be a fundamental part of the physical world.
